Old March 20th, 2011, 13:28   #1
enki
Angry VW Dealership caused damage to my brand new Golf
So I bought my brand new 2011 Golf TDI about three weeks ago. Part of the purchase agreement included the chrome exhaust pipes that they had to order. A few days ago I brought my car in to get them installed. They look great, and I thought they did an excellent job installing them.
I was wrong.
I was walking back from the supermarket with my wife today and saw a huge dent on the underside of my car. Obviously I was extremely upset and originally thought it was from some kind of road debris or something. Upon further inspection, I found four dents and a gouge on all four sides of the car (front and back on left and right side). They were clean dents and didn't look like I could have hit something. I looked even more carefully and saw that they were lined up on both sides, exactly where the car was lifted when they put on the exhaust pipes.
I am fuming right now that my VW dealership's repair shop could have caused such damage on a simple job. I can't see how this was caused by anything other then sheer negligence on their part.
I just sent them an email with attached pictures showing them the damage and making it clear that I expect them to fix it immediately and put it back in the like new condition.
Since the car is so new, it's only been to the shop once, and the damage is clearly from the car lift, I assume they will not try to argue the matter with me.
Has anyone else had this problem before? The part that is damaged looks like it's attached to the side panels. Is it going to be a major body shop repair to fix, or can they do it without removing anything?
(Extremely large pictures removed since they were distorting the page size, and based on the comments below and follow-up information showed that most were not 'damage')
ARGH!!!!!
2011 VW Golf TDI - Reflex Silver, Bluetooth, Cold Weather, Rubber Mat Kit, Chrome Exhaust
James Babiak
Last edited by enki; March 20th, 2011 at 16:52. Reason: (Extremely large pictures removed)
enki is offline   Reply With Quote
Old March 20th, 2011, 13:29   #2
enki
Sorry for the REALLY large picture sizes. I wanted to get as much detail as possible, so I took them at high res.
James Babiak
Old March 20th, 2011, 13:42   #3
Ryephile
Ryephile's Avatar
TDI(s): MkVI Golf
Those are the 4 arrows stamped into the rocker panels [2 on each side] to show you where to lift on the crush rail. The dealership didn't do anything.
'11 Golf TDI :: 6MT 4DR :: Reflex Silver
KW Variant 1 coil-overs :: VW Mud Flaps :: Frost Heater :: Opti-Lube + B2
Ryephile is offline   Reply With Quote
Old March 20th, 2011, 13:49   #4
Arne in Oregon
Arne in Oregon's Avatar
TDI(s): '10 Golf MT6
Fuel Economy: 41+ MPG lifetime average so far
I agree. The owner's manual will even show those "dents" as how to locate the jack points.
2010 Golf TDI, 2 door, MT6, United Gray
Options - sunroof, bi-xenon, cold weather, mats and mud flaps
Mods - euroswitch, painted side moldings, clear bra, 17x8 TSW, GTI cat-back/valance, Draw-tite hitch
VCDS - No DRLs, no seatbelt chime, no horn on lock, windows/sunroof open/close w/remote
Arne in Oregon is offline   Reply With Quote
Old March 20th, 2011, 14:02   #5
ihatespeed
Guest
the small arrow shaped dents are there on purpose, if there is other damage then by all means lace up your a** kickin boots..
Old March 20th, 2011, 14:02   #6
POWERSTROKE
POWERSTROKE's Avatar
TDI(s): 2002 Golf
Those are supposed to be there. It is where you place a jackstand on the pinch weld.
It's kind of fun to do the impossible.-Walt Disney
POWERSTROKE is offline   Reply With Quote
Old March 20th, 2011, 14:14   #7
Ideliver
Fuel Economy: 36
I think all VW's have these dents ,I thought the dealer damaged mine to but checked other cars on lot and they had same 4 dents also.
Ideliver is offline   Reply With Quote
Old March 20th, 2011, 15:29   #8
IMAAaron
Soooeewww.... Pics of the tips??
IMAAaron is offline   Reply With Quote
Old March 20th, 2011, 16:08   #9
timwagon
I also wouldn't consider them "huge dents". I had trouble finding them when I rotated my tires the other day. "Barely noticeable indentations" would be a better description.
timwagon is offline   Reply With Quote
Old March 20th, 2011, 16:11   #10
enki
Wow, that does make me feel a little better. I just checked out my wife's 2006 Jetta and she has them too. Her's aren't as noticeable since the car has 5 years of wear on it too.
While that does explain 3 out of 4 of the 'dents', I still think that one was damaged in excess of the factory arrow dents. I've attached a closer (and smaller) picture showing what I mean. There is a flat gouge on the left side of the arrow, and a circular dent on the right side. None of the other three have that. It makes it very noticeable, and is what originally drew me to thinking my car was damaged. You can even see it when standing next to the car. So it looks like while they caused some damage, it wasn't as bad as I originally thought.
Fortunately I didn't send my email yet, as we had to run out to a party. I'll change it to mention only the extra damage. Does everyone agree that those additional dents are damage? Should they be easy to remove?
Thanks for everyones help!!!
James Babiak
Old March 20th, 2011, 16:25   #11
enki
Here are three other pictures showing the damage to the one spot from three other points of view.
James Babiak
Old March 20th, 2011, 16:35   #12
enki
Here ya go:
They look pretty sweet. I had them stagger them too, so they curve with the rear bumper. At least they didn't screw that part up (that I know of!).
James Babiak
Old March 20th, 2011, 17:00   #13
BMLO13
BMLO13's Avatar
It looks like the "cups" on the kift arms hit your rocker panels. Bad mechanic, bad!! I have seen some pretty bad things happen on car lifts. I hope the dealer has no problem with fixing it.
BMLO13 is offline   Reply With Quote
Old March 20th, 2011, 17:04   #14
enki
Do you think it would be easy to fix? I have no idea about body work, and I would hope they could do it without tearing apart the car. I really don't want to have to worry about them accidentally putting it back together wrong or causing even more damage in the process.
James Babiak
Old March 20th, 2011, 17:16   #15
IMAAaron
It's really going to come down to the body shop and you won't know until it's over if it was worth it, I think. Each body shop will 'blend' it differently. If they have to spray the damage, different shops blend to different trauma diameters.
Personally, I wouldn't be happy if they resprayed clear coat up the door or over sprayed the undercarriage. It's a new car. I personally might live with the damage in fear of shoddy body work.
Hail damage while at the dealership mainjet General VW Discussion 24 September 6th, 2007 13:02
Oil leak caused by dealership--HELP schatzie VW MKIV-A4 TDIs (VE and PD) 26 November 27th, 2002 09:40
Door Damage caused by VW factory roof rack NEBUR Upgrades (non TDI Engine related) 2 September 9th, 2002 23:53
New DC/Maryland Area VW Dealership: COOK VW Beowulf General VW Discussion 4 March 17th, 2002 08:56
Page generated in 0.19612 seconds with 11 queries
[Output: 128.50 Kb. compressed to 107.27 Kb. by saving 21.23 Kb. (16.52%)]
