Fahrfuwerfuelen
The only biodiesel available in my area is B100. I'm considering mixing in biodiesel with diesel #2. Any thoughts on the proportions? Any preference as to which fuel should go into the tank first?
My understanding is that BD is slightly denser than #2, so BD should be added after the #2 for optimum mixing. In real life I dont think it matters too much, since the fuel pump is constantly recirculating and mixing.When blending I prefer to put in biodiesel first.
Any recommendations on what type of conditioner I should use and how often it should be added?B20 is 20% Biodiesel and 80% Diesel #2, B35 is 35% Bio/65% #2, B50 is 50% Bio/50% #2, and so on and so on.....
You can mix as you wish, in Hawaii all you have to worry about is water/condensation in your fuel. At first glance it may appear that there is little or no water in the fuel. If you check early in the morning when the temperature is lowest, you'll see the condensation on the sides of the container/tank that the fuel is being stored in.
In California there are TDIClub members here in California that run straight B100 with no complications. I have read on this thread that 50/50 is a perfect mix.
Good luck and don't forget to add some type of fuel conditioner and at least 4 points of cetane.
JAY GARRETT, Los Angeles, CA. hazw8st@onebox.com
a cetane boosting fuel conditioner is almost always a great idea, but the cetane of Pacific BioD is already an amazing 61.5! i would not add a cetane boosting conditioner to their B100.don't forget to add some type of fuel conditioner and at least 4 points of cetane
Is there a recommended additive if you're running B20?don't forget to add some type of fuel conditioner and at least 4 points of cetane
Excellent question. I have not seen the cetane info posted anywhere at all either. Heck, most places I have seen who offer biodiesel advertise just that -- biodiesel. I'll call around and see what I can find out too.How do you know what cetane is for the B20 at the pump? I haven't seen it on the (soy based) B20 pumps local to me.
you may have good luck at marinas. lots of boats use diesel engines and the fuel conditioners they use are either the exact same as the ones we use or they're the exact same in different packaging.Thanks, I'll try to find a retailer here in Hawaii who sells that product. Although, Hawaii doesn't always carry products easily found on the mainland.
