Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Future TDIFests
Future TDIFests Discussions about future TDIfests
Closed Thread
Old September 13th, 2013, 14:15   #271
Good Ol' Boy
VeeDubTDI's Avatar
Note that the ALH only takes atmospheric readings when you first turn on the ignition, so there is no live altitude compensation as you drive. Good practice might be to turn off and restart the engine when you get into high altitude.
(At least that's my understanding of it...)
VeeDubTDI is offline
Old September 13th, 2013, 14:16   #272
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
The TDIfest 2001 in Park City had 3 FAILED turbos. Now these were ALH cars.
And "back in the day" I had an Upsolute tune & .205 Injs. I did take it easy over the Mtns out and back, I had no problems.
From past reports those that did have probs 2 were driving aggressively. The third was a NB that failed on the way home. Dang it I remember those facts but can't remember breakfast!
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline
Old September 13th, 2013, 14:18   #273
PeterV
PeterV's Avatar
Default Barometric readings
Thanks Lawson I now remember that idea.
PeterV is offline
Old September 13th, 2013, 17:25   #274
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
I'm happy to continue with the TDIFest efforts, as are a number of other people.
I have mixed feelings about that.
One one hand are those complaining that the same 'clique' is always running the fests, so they don't feel wanted / needed, while others are content to sit by and let those that have organized previously, do yet another event
It's a self-fulfilling prophesy.
I'm deliberately trying to goad those that haven't organized an event into proposing one so that the same group that have run events in the past aren't hurriedly pressed into rush mode for next year because no other group has.
Svante Arrhenius 1896
Lug_Nut is offline
Old September 13th, 2013, 17:57   #275
romad
romad's Avatar
As long as the tune is set up to adjust for altitudes and you don't do anything too aggressive I would think you'd be fine. But I will tell you we ship a lot of BEW replacement turbos to Colorado. Stock or tuned, it doesn't seem to matter.
Hmmm, maybe I should avoid going through Colorado and stick with the southern route if I ever again drive across the country, or even going to Tahoe.
The fleet:
romad is offline
Old September 13th, 2013, 19:25   #276
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
All TDI ecu have atmospheric pressure sensor Inside, you dont need reset the ecu when you rise in altitude.
At de top of Mt-Washington, i take picture of Vagcom...
970 to 1050milibar at sea level, 795milibar at the top!
http://www.dieseleux.torquedelight.c...C00489.JPG.php
The pressure drop aprox by 10% per 1000 meter, this is rule of thumb.
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline
Old September 15th, 2013, 09:24   #277
Jayg
Jayg's Avatar
I love how even the tdifest planning thread has tech info.
Jayg is offline
Old September 16th, 2013, 06:04   #278
n8ronJ
n8ronJ's Avatar
I agree but isn't that going to happen in any organization? There are a lot of people - myself included - that cannot plan much of anything. But on the other hand they are pretty good at assigned tasks. The reason I posted a list of questions a few pages back was to find out a little bit more of what's involved in the committee/planning/feet on the ground work.
The few that take the reigns and run with event planning are usually very good at what they do. And the rest of us - no one want to go to a Fest (dis)organized the way I would do it. And for those that complain about it being a 'clique'... It's on each individual to get involved in the way that they desire to and are able to.
sold2003 Jetta GLS TDI, 275k, Platinum Grey, 5 Speed, SBC Stage2 Daily, Evo Atlas Skidplate, RC3
n8ronJ is offline
Old September 17th, 2013, 05:20   #279
Lug_Nut
Lug_Nut's Avatar
Some of those that have been instrumental in organizing the past several fests have 'day jobs' doing pretty much the same. It has been a huge benefit to have been able to make use of this expertise in our little weekend. It just that I don't want us to go-to-the-well once too often and imply that there is an expectation that these pros will bail us out.
I also have heard grumbling from several members about a nebulous, self-select group "running" TDIClub. I want to assure those with similar opinions that they can help guide the club if they get involved.
So, PLEASE, put together your proposal, submit a basic outline, identify others that have similar desires that can commit to helping, and let's resume having competing proposals.
Lug_Nut is offline
Old September 17th, 2013, 11:53   #280
cevans
TDI Parts Ninja Vendor
cevans's Avatar
To compliment these people, these people are also some of the most involved, most hard working club members who are dedicating lots & lots of time to this. If others were putting in as much time they too would be part of the nebulous extraordinaire.
IDParts.com - IDParts.com Vendor Thread - The IDParts Blog - IDParts YouTube Channel
My Diesel "Addiction": '17 Canyon 2.8L DMax, '11 R350 BT, '06 E320 CDI // Past: 15' Ram ED, '13 NMS, '10 JSW, '10 Jetta Sedan, '07 R320 CDI, '03 Wagon, '00 Golf 2-Dr, '00 NB (Yellow :-)
Stop Hunting for Torque Specs - Get A Free IDParts Torque Spec Poster Today!
cevans is offline
Old September 26th, 2013, 05:02   #281
ClutchKargo
ClutchKargo's Avatar
Fuel Economy: 48 - 54 mpg
Just throwing this out there......I'm an old member getting ready to get back into the TDI world. So how about the Pigeon Forge/Gatlinburg area. Tons of hotels, restaurants, place to go, brand new convention center and plenty more for endless activities. They (tourist association) host quite a few GTG's like TDIclub Fest and I'm sure they would love the influx of members.
Smoky Mountains, Cherokee NC, Tail of the Dragon US129 are all within an hour or so drive.
Good to be back soon at the Diesel pumps,
Clutch
2004 Golf GLS TDI-VWMikel Stage 3 tune / PD150 injectors / PD150 Intake manifold / PD150 Turbo Inlet pipe / R32 Airbox w/Euro DSG snorkel / VNT-17/22 turbo / Audi TT short shifter
Audi TT lower control arms / Matt Whitbread custom FMIC / 3 bar MAP sensor / Frank06 Stage 2 cam w/black lifters and oil-mod bearings / SBC Stage 3 clutch / BFI Stage 1 motors/tranny mounts / KW V2 coilovers
ClutchKargo is offline
Old September 26th, 2013, 12:25   #282
Good Ol' Boy
VeeDubTDI's Avatar
Clutch
I spent several months looking into that area specifically. It's peak season for tourism and good deals on hotels must be booked at least a year in advance, particularly for large groups like us. It would be a great location, but will require a lot of advance planning in order to pull it off.
Old September 26th, 2013, 21:10   #283
TomJD
TomJD's Avatar
Fuel Economy: 43 worst - 49 avg - 59 best
Not gonna lie, when I first joined the club I felt the same way. But people need to realize that this club has been around for, what, nearly 2 decades? So there are groups of people that know each other. Seems like the same people who run the fest also run the forum. Look at the moderators and its the same people who are most active at fest. It makes sense simply because those are the ones that are most invested in the success of the club, and also are the most obsessed.
I personally would love to have more involvement in the forum running operation and have mentioned it from time to time on different locations around here. But I guess my services aren't needed yet. I just know when there is a lull and people are tired of checking tdiclub.com they will look for people to take over the reigns.
So yeah, there are definitely little groups within the club but if people show initiative, I have never seen them discredited.
I'd like a fest in St. Louis, but I wouldn't be able to do it by myself. And I know Oilhammer and Dozenspeed are pretty busy people with busy schedules.
Tom
2000 VW Jetta TDI-3 pedals
TomJD is offline
Old September 26th, 2013, 22:27   #284
Dozenspeed
Dozenspeed's Avatar
Fuel Economy: $10,457 per TB change
It does seem to me that a fest in St. Louis is far away from gelling, but IF a strong team lead is formed into contention, I hereby would commit to supporting it by devoting substancial time to creating, coordinating and running a unique, family-friendly TDI-driving activity I've formed in my head that I think of as a live-action variant of our Picture Hunt Scavenger Game. I'm confident I have it fairly well thought out and can sell it to the TDI elders.
I do not want to be the leader per se but would be proud to take part of a competant brigade. I just don't have enough familarity in the standards and expections of Fests to promise more than that, so for now I'm standing by in the wings, ready to be called upon if desired.
I made one previous effort investigating a venue that simply fizzled, and only just now have thought of another possible venue of appeal that is making me reconsider trying again during the writing of this sentance.
The big fear about it being here is our wacky weather, but as it is still unusually hot here today this year, chances are next labor day will be gorgeous.
I really would enjoy contributing in this way, and think my local knowledge, experience and interests would be ideal for the activity I have in mind.
Sincerely,
Dozenspeed
Do you have a MK6 Jetta SEDAN? (2011-2015) Contribute to our mileage thread here! Over 70 cars and 3.5 million miles of data!
Dozenspeed is offline
Old September 27th, 2013, 06:33   #285
I don't think TDIClub is different from any other in that there's a core group of people who are involved, committed, and donate their time and energy to running the forums and making events happen. If I'm not mistaken there were not many forum moderators on the Fest planning committee, not that it matters, IMO. I was involved in the '07 Fest Planning but folks were uncomfortable with a vendor taking an active role in Fest planning, so I've stuck to donating items for the Fest since then.
Waiting to be asked to help probably isn't going to work. If you want to help out with a Fest put a team together and generate a proposal, or get involved with folks who are. I don't think anyone will turn you away.
2002 Jetta wagon, 384K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 260K; 2011 335d, 60K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
IndigoBlueWagon is offline
Closed Thread
TDIFest 2013 -Looking for Expressions of Interest VW Derf TDIFest 2013 3 October 31st, 2012 15:26
Interest in a DYNO at TDIFest this year?? VeeDubTDI TDIFest 2012 43 August 23rd, 2012 21:33
TDIFest 2012 -Looking for Expressions of Interest VW Derf TDIFest 2012 61 December 6th, 2011 12:18
Central Florida TDIFest Proposal Interest eluwak South Eastern USA 16 September 27th, 2006 13:15
Interest in CD of TDIFest 2003 Pictures VW Derf TDIFests 2000 - 2003 0 October 7th, 2003 20:34
Page generated in 0.18729 seconds with 11 queries
[Output: 141.52 Kb. compressed to 119.72 Kb. by saving 21.81 Kb. (15.41%)]
