LBJ (Laser Blue Jetta)
I've got an '09 TDI Sportwagen and am very disappointed in the headlights. I drive a lot in winter and these lights have a lot of vertical light scatter which is very bad in snow. Has anybody found a projector headlight retro kit that works for the '09? All I've seen are ones that claim to install up to '08.
I'd consider the fog lamps but unless I could just run with fog lamps and the marker/tail lamps, they wouldn't do me any good if the DRL can't be turned off.
I see that ECS tuning has a light switch with more lighting options that ON/OFF but it seems to require VAG-Com to make work and I'm without access or knowledge of such. So, I'm hoping for a simple headlight replacment.
