Software Mechanic
Several people have said winterized diesel reduces fuel economy by up to 10%. I did some research on how refiners produce winterized diesel. The information below is from Chevron and Exxon.
There is a belief that diesel is winterized by adding kerosene. This is not true. Kerosene is a high sulfur fuel and does not have the characteristics that high speed diesel engines require. It is more cost effective to include additives that prevent fuel from solidifying, i.e., lowering the gel/cloud point. Blending low sulfur diesel #1 with the #2 diesel sold for vehicle use will lower the gel/cloud point although it is typically more expensive than using additives.
Exxon in its diesel fuel FAQ says "the use of Diesel Fuel No. 1 reduces power and fuel economy, and often is more expensive, so minimizing the amount of No. 1 Fuel in the blend is an important consideration."
If one were to add #1 diesel, refiners recommend blending no more than 20% #1 diesel which would lower the cloud point by about 5°F. This would decrease fuel economy by 1% as #1 diesel has 95% of the energy content of #2 diesel. You would also need to consider if the winterized fuel already has #1 diesel added.
Chevron says "When they work, additives have several advantages over dilution: they are readily available in most areas of the world, treatment cost is less, and the treatment does not lower fuel density (thus heating value and fuel economy are not affected)." (page 8 of Chevron's Diesel Fuels Technical Review)
Since additives can reduce the gel/cloud point by up to 50 to 70°F (30 to 40°C) (page 86 of Chevron's Diesel Fuels Technical Review), another cause of winter fuel woes must be considered, water in the fuel.
In the many years of driving a diesel and tracking fuel consumption I have not seen a noticeable drop in fuel economy. I have noticed that my TDI accelerates better in winter which is most likely due to colder air being denser. I live in Oregon's Willamette River valley where winter temperatures are in the 30s and 40s.
