Old October 2nd, 2019, 18:00   #1
clyde
Default Winterized diesel fuel
Does winterized diesel fuel offer any benefits other than its lower gelling temperature?
clyde is offline   Reply With Quote
Old October 3rd, 2019, 02:37   #2
Tdijarhead
It hurts your mileage and costs more.
But you will not be stranded alongside the road with a car that does not run or barely runs with no power.
Old October 3rd, 2019, 11:00   #3
scooperhsd
Clyde - are you down in FL ? If so, it's not very likely that you will see much "winterized diesel locally. OTOH - if you want to make a trip north this winter - you WILL get it when you fill up with local fuel. In fact, one of my points about winter driving is that if you're going from a warmer location to a colder location, that you fill up with local fuel before shutting down for the night, so your car doesn't have issues starting / running due to fuel.
You can also buy additives that can help lower the gel point and deal with water in the fuel . One that i use is Powerservice in the WHITE containers - the Silver is to improve running on summer fuel. There are other fuel treatments out there that will also work.
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is online now   Reply With Quote
Old October 9th, 2019, 15:30   #4
Riflesmith
Riflesmith's Avatar
Winterized diesel fuel is supposed to mean fuel with a lowered CFPP and gel point via anti-gel additives. These additives shouldn't effect fuel energy content.
Winter blend diesel fuel has #1 diesel added in some quantity. This is a reliable way to lower CFPP and gel point, but does reduce the energy content of the fuel, resulting in lower MPG.
All of that being stated, buying diesel fuel, winter or summer, is a crap-shoot. You never really know what you're getting.
Riflesmith is online now   Reply With Quote
Old October 10th, 2019, 09:25   #5
Lightflyer1
Lightflyer1's Avatar
Well you do know the minimum standards but not much else. It could be way above that or at the line at the bottom.
Old October 10th, 2019, 11:02   #6
scooperhsd
About the Diesel #1 - not necessarily all winter blends. It is one method to lower the gell point, but there are other ways to lower it as well. You can get #1 in ULSD as well as #2. But the points about always buying your fuel at a station with high turnover (always important, but even more so in winter) also apply.
Winterized Diesel and My Fuel Economy 3114Milwaukee TDI Fuel Economy 32 December 24th, 2013 21:25
Winterized diesel Software Mechanic Fuels & Lubricants 30 January 30th, 2009 00:47
Mileage hit from winterized diesel fuel? stancho TDI Fuel Economy 2 November 14th, 2007 17:10
Are fuel stations required to sell winterized fuel? y2kbird Fuels & Lubricants 17 February 20th, 2007 19:52
winterized diesel kory Atlantic Canada 6 November 8th, 2006 18:16
Page generated in 0.13543 seconds with 12 queries
[Output: 75.13 Kb. compressed to 65.92 Kb. by saving 9.22 Kb. (12.27%)]
