Old February 9th, 2017, 18:40   #1
miatamike203
Fuel Economy: 44-50 with PP520 best was 56
Default Bosch injector calibration
I can't find any place in the northeast that can calibrate my race 520 nozzles to the pressures i need. 230/320 bar perssures.
1999.5 Jetta 5 hole R52, GT1752V billet comp, stage 5 Malone tune, 11mm IP, upgraded SMIC and piping, pd150 intake manifold, carter 72gph lift pump, spec stage 5 VR6 clutch, EGR delete, 2.5" downpipe, 3" catback.
Race pipe with ASV & heat exchanger
miatamike203 is offline   Reply With Quote
Old February 9th, 2017, 19:45   #2
RoseBud68
I take it you don't want to send them out.
1999 MK3 Jetta TDI 1Z.
RoseBud68 is offline   Reply With Quote
Old February 9th, 2017, 19:53   #3
miatamike203
I would prefer not to, and I know DBW will not set them for me. I found a place in CA but thats really the only places i could find so far.
Old February 9th, 2017, 20:50   #4
[486]
TDI(s): 02 golf ALH
buy a surface grinder
buy a 0-1 mic that reads tenths
buy a porta-power
buy a suitable pressure gauge
buy a lathe to make the necessary adapters (I found that M14 lug studs from GM trucks work great as they're the same thread as the injector bodies)
and a bunch of other scientific apparatus you can source from your local meth lab
make the injectors single stage
set the pressures all close enough to the same
assemble the injector lines on the pump 90 deg off and put the injectors in the proper order so each gets fuel from its proper delivery valve
use an old computer power supply to give the QA 5V and the shut down plunger 12v
put 1/4" rubber hose over the nozzles into graduated cylinders
spin the IP with an electric drill until you've got a good amount of fuel to measure
increase pintle lift on injectors with low output
or just plop them on there, hope for the best and call it good enough
My dssr 360s are single stage converted and set to somewhat similar opening pressures, but not flow balanced at all, seem to work just fine so far.
[486] is offline   Reply With Quote
Old February 9th, 2017, 20:53   #5
miatamike203
buy a porta-power
I have the lathe and i have a old bottle jack i could build the pop tester but with what im also working on i dont know if i wanna go single stahe
Old February 9th, 2017, 21:14   #6
[486]
TDI(s): 02 golf ALH
only downsides I've found reference to are higher NOx emissions (same as advancing your injection timing, larger nozzles, or both) and more noise, which I didn't notice at all when I swapped mine over.
Old February 9th, 2017, 21:53   #7
andy2
andy2's Avatar
I'm working on setting up my newly acquired ALH Gibonta DLC .240 nozzles using an ebay/india pop tester and the homemade test tool to be able to test both stage pressures separately.I just broke the handle on the tester tonight but will have it fixed soon.Seems that 300+ bar is just too much for this pop tester.I had a couple of #3 injector cores and one just happened to test at 215/310 bar without any work so I'm just setting the other three to the same within +/- 5 bar approx.Should be interesting to see how they work.
andy2 is offline   Reply With Quote
Old February 10th, 2017, 14:58   #8
miatamike203
Nice i would try to do them myself but i dontbhave shims or know where to buy shims. I wish DBW would do them but i know they won't as i got the nozzles used. They did a great job on my pp520. I had found a place in CA that will do them but there wait time is long.
Old February 10th, 2017, 18:53   #9
[486]
TDI(s): 02 golf ALH
I just cut my shims to make them all closer to eachother, only had one that I actually had to cut down.
Old February 11th, 2017, 19:47   #10
sakonnet_TDI
TDI(s): 2000 Beetle
There is a company I used in Portland Oregon called Diesel Fuel Injection Service or DFIS. They were a good price and excellent service.
sakonnet_TDI is offline   Reply With Quote
Old February 12th, 2017, 17:19   #11
miatamike203
I emailed them we will see what they say.
Injector calibration? Jonamond Ontario 19 March 23rd, 2017 18:08
Bosch 4 bar MAP sensor - calibration? bhodgkiss TDI Power Enhancements 4 September 24th, 2015 18:29
Injector calibration Jet 02 TDI Power Enhancements 3 August 7th, 2014 18:40
Injector Pump Calibration???? Gpdieselbeetle TDI 101 2 March 26th, 2010 12:16
Bosch va/ve injection pump calibration kit ebay mojogoes TDI Power Enhancements 0 August 3rd, 2007 02:01
Page generated in 0.18156 seconds with 11 queries
[Output: 107.20 Kb. compressed to 91.35 Kb. by saving 15.85 Kb. (14.78%)]
