Old February 10th, 2015, 19:58   #1
Dimahuber23
Default 2006 jetta Glowplug Relay location??
Hi i was wondering if any one know where the glowplug relay is located in a 2006 Jetta TDI 1.9L. I was looking but i cant find it anywhere.
please help
thank you!
Dimahuber23 is offline   Reply With Quote
Old February 11th, 2015, 09:34   #2
JB05
Fuel Economy: 43/41/40
On my '05 Golf, the GP relay is located at the base of the windshield, under the plastic cowl. I would look there; you might see it through the vents, more toward the driver's side.
JB05 is offline   Reply With Quote
Old February 12th, 2015, 07:27   #3
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
One of two spots. IN the fuse box under the hood or UNDER the fuse box on a slide out panel. It's pretty obvious if you look under it on the engine side.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old February 13th, 2015, 23:00   #4
Dimahuber23
thank you jason i found it exactly underneath the fuse box, hat to take the battery out to get to it.
1998 jetta tdi flasher relay location thetick TDI 101 1 March 28th, 2009 17:07
Location of A/C relay, Fan Relay? 2000 TDI Beetle Other? Redty VW MKIV-A4 TDIs (VE and PD) 11 June 27th, 2007 20:23
98 Jetta Turn Signal Relay Location dkisling VW MKIII-A3/B4 TDIs 1 September 20th, 2005 08:12
Hard starting, was Glowplug relay location T5TDI VW MKIV-A4 TDIs (VE and PD) 15 November 5th, 2002 07:44
Glowplug relay location B3Syncro VW MKIV-A4 TDIs (VE and PD) 3 November 2nd, 2002 10:56
Page generated in 0.11842 seconds with 11 queries
[Output: 61.76 Kb. compressed to 55.26 Kb. by saving 6.49 Kb. (10.51%)]
