sixpointsI
Just bought my first TDI 2014 Jetta. I Have yet to fill it up. I live in Brooklyn, where there a lot of truck stops and there are many fuel choices. Which combo or lack of #1, #2 and DEF (sold at the pump) is best?
Ahhhhh DEF.....wasting fuel tank space on class 8's since 2010....
I have no idea what this post means.And somehow my 2011 Granite with scr is taking to school by our 88 mechanical RD688S....no cat, no DPF, no scr
....and the RD gets better milage, even with 500 ft/lbs less torque and 100 less hp.....EPA is chocking the life out of diesels, big and small.....
Agreed.And somehow my 2011 Granite with scr is taking to school by our 88 mechanical RD688S....no cat, no DPF, no scr
sounds like trucker lingo to meI have no idea what this post means.
Except with the extra MPG it allows, it doesn't matter. SCR is a NOx treatment than happens post combustion, unlike the alternative which is just more EGR. So it lets the engine run leaner, which gives it better fuel economy. This is why the heavier, bigger Passat gets better MPGs than a Jetta or Golf with the same output and size engine. It further increases fuel economy by allowing for less soot generation, which means fewer DPF regens, which use fuel to do so.
I can probably brew some up in my basement and make a fortune.Sure. They give you a first little trial bit of DEF for free and as soon as you are hooked on it the price goes sky high!
LOL
Bill
Its already happening. On my GM forum, Def at the dealer is $25, same part number, same fluid somewhere else is $8. Numbers might not be accurate but close enough for this talk. In my neck of the woods, Def averages $18, hop across the line, $8. I can see it adding up but if your getting better MPG, it should be a wash.All true but expect to see that playing field leveled out a little with the declaration of "fluid economy" of some sort.
Since DEF is a consumable for going down the road, while cheaper than fuel, it isn't free. The trucking industry is moving toward declaring how much DEF and Fuel their trucks consume. I doubt it'll be long until people start playing with the prices of DEF and kicking owners where it hurts. When they need it, they have to have it...I'm just not sure suppliers have quite figured that out yet.
Sure you can, go piss in a cup,I can probably brew some up in my basement and make a fortune.
DING DING DING...you winsounds like trucker lingo to me
What is the MPG difference between the new Mack and the old Mack?And somehow my 2011 Granite with scr is taking to school by our 88 mechanical RD688S....no cat, no DPF, no scr
Ooh, conspiracy theories!
