driving back from north dakota.
cold as F!, so when i parked at the rest stop to grab 30mins of sleep, i woke up to a triangle on dash, warngin on console. i turned car off, back on, warnings gone, seems to drive ok, but vcds shows this in history. i cannot remember the 1st word, but the 2nd one was transmission, and obviously that area of car was highlighted in orange/yellow.
Saturday,24,November,2018,03:31:58:13856
VCDS Version Release 18.9.0 Running on Windows XP x86(VirtualBox)
www.Ross-Tech.com
Jason's Workshop
Address 02: Auto Trans Labels: 0D9-927-770.clb
Control Module Part Number: 0D9 300 041 N HW: 02E 927 770 AQ
Component and/or Version: DQ250-6F MQB H53 4512
Software Coding: 0014
Work Shop Code: WSC 00066 790 00202
ASAM Dataset: EV_TCMDQ250021 001001 (VW37)
ROD: EV_TCMDQ250021.rod
VCID: 236B14C92AE3D852E8-8077
2 Faults Found:
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
21197 - Transmission Control Unit
P1701 00 [008] - Locked
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 0
Fault Frequency: 1
Mileage: 54570 km
Date: 2018.11.24
Time: 03:20:37
fuzz under 34K miles. very odd all this goofy **** is happening just before warranty...
warning is gone, i didn't clear codes, is it worth it to make a stink at the dealer? unfortunately i didn't take a photo with the phone. the ass**** that ive been working with says they can't do anything unless theres a 'check engine LIGHT", but in this scenario it's not emissions related, hence no light, just warning triangle and console message.
luckily there's stored history.
www.Ross-Tech.com
Jason's Workshop
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 54570 km
Date: 2018.11.24
Time: 03:20:37
