towforce
It's far from cold up here on the West Coast but I just noticed our Jetta TDI is getting a little grumpy with its "cold" starts. Brief, stumble and a bit of smoke.
Could be many things ranging from a leaky injector, age and or the fact I just recently did a timing belt and have yet to check the torsional/timing values but I got thinking... Is there any possibility the glow plugs have failed (or failing) and have not thrown a CEL? (yet?)
As for a little bit more background, at 175,000km's my local VW, did the flash and conversion to steel plugs. Thing is, that was back in 09, we are now at 410,000km's and its 7 years later! That's 7 years and 235,000 km's with the same steel glow plugs. Is this a "LONG" time for a set of GP's to last or in warm climates is it normal? (no not warm like California but probably no more the few dozen starts below 0 Celsius per year).
Funny enough, almost 6 years ago I purchased a full set of steels GP's from IDP (supposedly for the post ECU flash update) and they are sitting on the shelf. Wondering if I should just throw them in? or should I just wait for a code to be tossed and stick to checking my timing during my next service?
Cheers
Martin
Cheers
Martin
