Quick question here, I have a 3 bar map and wanted to see what boost was going at full throttle.
At 3318rpm vcds was recording 2550.6
Is this in milibar? and will it still read the same even though the stock sensor is 2.5 bar?
If so that would be 36 psi. Sounds alot for a vnt17. Or is this because I'm not accounting for environmental bar?
