1z starting issues
50harleyrider
charleston,wv
2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
That's strange.The ECU should be controlling all your starting inputs. If you have access to VAG, check all the temperature readings ie engine, intake air,fuel first.They should be within a few degrees of each other. Also check IQ to see if you're getting good fuel delivery. Does this happen on cold starts only? Your pedal is only a rheostadt control and it shouldn't be in the starting loop.
rdkern
Humboldt Co CA
i have to have my foot on the gas to get it to fire
any ideas pppl
cheers dan
Is this a diesel? If so, no gas.
As mentioned, throttle in the TDI is ignored until engine is running.
