So I changed my drivers side axle and at the same time replaced the ball joints, tie rod ends, sway bar links, spindles, brakes on both sides.
Now when at a stop with the wheel turned all the way I'm getting the sound like a small pump working hard. I can't think of anything I did that would effect anything to make sounds at a stand still. Unless moving the tie rod in and out caused an air bubble in the power steering? Any ideas?
I want to drive it about 15km tomorrow to get alligned but worried something else is wrong?
