scanchattanooga
I've got a 2004 Jetta TDI with the double DIN Monsoon stereo. Car has the CD changer cable assembly in the trunk, and I bought a USASpec DF-VW interface box so I could plug it up and link my iPod audio into the Monsoon. But, it doesn't work... just says NO CD whenever I try to access it. Have pulled the head unit and checked to make sure the cable is plugged up, disconnected and reconnected the battery, no go.
Any ideas? I'd heard somewhere that some of these radios came programmed from the factory such that they wouldn't recognize anything plugged up to the CD changer plug. If this is the case, am I SOL or can this be fixed by reprogramming with VAGCOM?
--mws
http://www.scanchattanooga.com/
--mws
