Anyone out there know if a factory Monsoon stereo from the 99-04 Passats would any way fit in a 98 Jetta? It doesn't seem likely...but thought I'd ask anyway.
FYI, I have a factory Monsoon Amp, headunit and CD Changer from an A4 Jetta. Fits in the factory spot just fine, a little wiring is needed for the amp, but it works. I will be up at this GTG: http://forums.tdiclub.com/showthread.php?t=128002
on the 18th, and could deliver the set to you then. Let me know via PM if you are interested.
-BB
