powerfool
I have routinely been getting ~50mpg after I completed the main maintenance on my Jetta after buying it last June (new LRR tires, vacuum hoses, MAF, ECT, thermostat, and turbo actuator). Prior to these items I was getting 39-42 mpg. In addition, I started adjusting my driving routine almost simultaneously. About 3k miles ago, my TB was changed and about 2 tanks ago (which is about a month), my FE dropped to about 45 mpg.
So it begs the question, does "summer" diesel (SD) have any impact on fuel economy? For SD, summertime means cracking home heating oil and likely more BD being added as winter diesel make have BD content not added in moderate to cooler climates (like the Midwest).
Now, I am asking this knowing that my drive time has changed and I have been driving a bit more aggressively, which is probably a bigger factor than anything else. But, I am still curious as to what others have experienced because last summer doesn't really count for me because my Jetta ran terribly then.
Thanks!
Thanks!
