mtushmoo
- Joined
- Nov 24, 2013
- Location
- MI
- TDI
- 97 Passat. 99 A6 avant in process. Parting '96 Passat. Parting '01 Passat Wagon.
http://forums.tdiclub.com/showpost.php?p=4707185&postcount=31 got me thinking about my 99 A6.
Before I rolled it in the garage the last time, I parked my truck next to it, stuck a hose on the fuel line in the engine bay and hot wired the girl pump to run, intending to empty the tank.
After reading this thread, I stuck the supply and return hoses together and ran the pump. It gurgled and belched for a bit, then found more fuel. I'm not even sure how mm ugh gasoline is still in it.
I had intentions of doing the H pipe thing. I measured the back pressure from the venturi pump at 21 psi.
How does a factory diesel manage this issue?
Does one of those vapor lines dump back to the tank so that I can use it for a non back pressure return?
