VSS signal to ecu
rooney77
Texas
2000 Beetle
I emailed ross-tech to see if anyone there can tell me. Andy emailed me back. I've got to get an auto-scan printout to him before we can move forward. Unfortunately I can't scan it till this afternoon so it'll probably be Monday before I hear back from them. I really hope someone there knows.
rooney77
Texas
2000 Beetle
Yes it's a 3 wire.
Exciting update. At Andy's, from ross-tech, suggestion I tried recoding the distance multiplier to 3 and I'll be damned if it didn't work. Crazy since everything I've read says the mkiv has only two options (2 or 4) but I plugged it in, it accepted it and now I'm never more than 5mph off of where the math says I should be. Very happy camper. Andy, thank you again for the help. :D
edit: And thank you to you Jimbote for all your advice and willingness to help. I owe ya a beer for sure.
rooney77
Texas
2000 Beetle
In vcds go to instruments, then coding. Should be a 5 digit number. The first two are for various equipment options, the 3rd is the country, the 4th digit is service interval and the last digit is your distance multiplier. Everything I've read says that the mkiv can only accept 2 or 4. Well that's obviously not the case. You just throw a 3 in there and see what happens. You can always change it back.
rooney77
Texas
2000 Beetle
I'm not trying to discourage you but I was the exact opposite at 25mph fast. For all I know coding it to 3 may be a sort of reset and reevaluate type function. Give it a go and report back but by all means, write down what it was initially.
[486]
MN
02 golf ALH
Okay, working with this on my 0a6 swap, this thread comes up on google with speedometer questions, may as well do it here.
02j has 22 teeth on the differential carrier and 13 teeth on the speedo pinion
using a sewing needle as a dowsing rod, the magnet that spins has 4 poles
so, 22/13*4= 6.77 pulses per axleshaft revolution
with 195/65/15s at a supposed 809 revs/mile that's something like 5476 pulses per mile. Call it 5500.
That may be double the proper number, as I don't know if the sensor is "seeing" both poles of the magnet, I don't know near enough about hall effect sensors. In fact I don't know if all 4 are N or S poles or alternating as I'd assumed. Oh well, thing's snapped back together and the screwdriver's outside.
A4 g/j/nb hub VSS is 43 teeth, which works out to 34787 pulses per mile with the same tires
6.35 times faster, dang, was hoping for something simple like 4x faster
5476/809= 6.77
so with a 7 toothed wheel at wheel speed I can get a close speedo signal. Almost right on (6.98) if I go to a 195/70/15
Hasenwerk
Vendor , w/Business number
Quesnel, BC
1982 Cabriolet (BEW|VNT17|Stage4), 1989 VW TriStar Syncro soon-to-be CR TDI (CBEA), 2001 Ford Ranger Edge 4x4 (ALH|VNT17|R520|Stage4)
The ECU's VSS input is 1Hz per 1km/h, so 100km/h (62 mph) is a 100Hz, square wave signal. Some ECUs like 5V, all will safely take 12V.
[486]
MN
02 golf ALH
Okay, so 60*60=3600 pulses per km
3600*1.61=5796 pulses per mile
So pretty dang close to my calculated number. Means that it triggers on all 4 poles of the magnet in the sensor. Thanks Hasen!
[486]
MN
02 golf ALH
wired up a ford edge trans output speed sensor I found in the trash and made a 7 tooth wheel, heat-shrunk it onto the left inner CV and made a bracket out of angle iron, it reads proper.
calculations say 3% off with my current 195/65 tires, not too worried. Will go to 205/70/15 or 215/70 next time I find some in the junk tires pile at work, then it'll only read 1.1% off.
