tdmsurfguy
What tranny are you going with? If it's a EWB who are you using to ship it over, how much did they charge, and is it already rebuilt or do you need to have it rebuilt. Hope it's coming along.
Thanks, the drive shaft info was the last missing peace and now my parts list is mostly complete for a basic conversion:The right side drive axle is the same for auto/manual trans on the T4 92-2003, but the L side is different for auto/manual so you need to source the manual drive shaft for the L side when doing this conv, p/n 701 407 271P. The manual L side drive shaft is 10mm longer than the auto one
Justin
I would still use the AHU pump and convert the hose that is on the right to a regular hose/clamp to go on the AHU nipple..
those washers are asking for failure/working loose in short order.
