Thanks. Just turned 4000km on the swap yesterday. Been driving it to work, going camping and a couple weeks ago did a 7 hr round trip for a golf weekend with a buddy. Averaging 25mpg which I am really happy with.
Old thread, I know, but I just wanted to say BCZuk, that this build is AWESOME and a huge inspiration and point of reference for me doing a future ALH/R151-AX15/Dana18 swap into my Samurai with Toyota passenger side offset front and rear axles...
The front oil pump location and inability to clearance the front of the oil pan much at all does present some difficulties installing an ALH into a Samurai without a doubt. I figured if I were to shove the axle forward 1.25" further than it already is (it's all the way forward with the Toyota SPOA kit's adjustments as-is, have to driill one more set of holes in the perches and plates), and slam the vacuum pump back within 3/16" of the firewall or even clearance the firewall slightly for the vacuum pump, and modify the coolant flange similar to yours, I would vertically be clear between the front of the oil pan and the high steer kit tie-rod at full steering lock (rearmost position), and I may need to slot and elongate the Samurai manual steering box mounting holes slightly.
The panhard bar, I figure I'll have to chop it up and make a Z-bar offset in it like the inferior geometry high steer kits sort of, but the geometry will remain the same, it will just have a large offset to clear the oil pan...
I was wondering about this custom top you have... who made it, and are any templates available for this? I was looking at stretching a Rallytops SWB Samurai hardtop just by chopping the sides off in the middle of the window and forward, and re-'glassing them on at the front location where they need to be, and then just using a self-made mold of the middle straight sections of the side window area before the window curves up/down to vertical, and laying down fresh fiberglass in that area. Then purchasing a new RallyTops 2pc hardtop front cab roof.
A soft top would be nice.
Or find a rusted out Canadian LWB Samurai with the factory hardtop still on it. Importing a Maruti Gypsy top from India would cost a fortune, but there are raised roof rear soft tops available from India on ebay.
Oh yeah, I plan to stretch my frame to LWB specs and use an Aqualu aluminum LWB reproduction body...
GREAT WORK, I hope this thing is still running around in top form!
