99_golf_alh
What are the differences between the two nozzles if there are any? Are Rocketchip tunes compatable with both? Which are the better nozzles?
99_golf_alh said:What are the differences between the two nozzles if there are any? Are Rocketchip tunes compatable with both? Which are the better nozzles?
nobody... everyone knows he's into chickens.majesty78 said:Bob Fout, for whom did you have to explain your signature with words added???*g*
I believe block 13 in the engine section of vagcom shows the balance of the injectors. If the injectors aren't balanced you can have poor burning fuel, which can be bad for the cylinders, but thats about all I know on that.mrchaotica said:
- I happened to talk to Jeff about this recently; he strongly recommended the Sprints over the PPs (with the stock turbo) due to smoke.
- Jeff also strongly recommended against any turbo bigger than a 1749vb for street/daily driver use, but I see plenty of people with way more mods than that (e.g. Richard55) who don't appear to be having problems...?
- What's the deal with balancing injectors?
