iMac6
Hi Folks,
I have a question about the "symptoms" my 03 Jetta TDI is currently experiencing. I've looked through the forums and identified some of the things that could be kicking my car into limp mode at highway speeds. I've ruled out mechanical failure of the turbo, because boost is lost only intermittently, and turning the car off and then on again fixes the issue if only temporarily. However, there are a set of conditions that consistently will put the car into limp mode:
Thanks!
- It does not occur in gears 1-3, regardless of RPMs or speed.
- In 4th gear, the car will consistently go into limp mode at 3500-3750 RPM, most predictably when the engine is not fully warmed up.
- A CEL light for "Overboost Condition" will sometimes be triggered (but sometimes it won't).
- The CEL may turn itself off or I may have to clear it myself. I've had it happen both ways.
- Turning the car off and turning it back on will resolve the issue. It may fix it for the remainder of the trip, or it may drop back into limp mode in 5th gear at around 70-80mph if on the highway.
Thanks!
