Old May 21st, 2020, 06:29   #1
C_Free
Default Instrument Cluster Woes
I recently took a B4 out of storage and the instrument cluster was dead. Backlights work, and I cleaned all ground points on the vehicle.
I put a cluster in from another B4 to test and that cluster worked great which leads me to believe the cluster is bad, maybe the voltage regulator.
I finally found a shop that would agree to fix the cluster, but after a week they said they couldn't fix it. I checked around and no clusters were found on car-part.
I really just want to get the car up and running, and I need to have the mileage checked by the BMV so I need a working cluster.
Does anyone in the forums work on these anymore? My soldering skills are poor; I'm afraid I'll damage it.
I'm also open to buying a used one if I can find one.
Thanks guys
leider geil!
C_Free is offline   Reply With Quote
Old May 21st, 2020, 21:30   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
jetta ,97 used to repair clusters but not sure if he still does
Seatman is offline   Reply With Quote
Old May 22nd, 2020, 11:15   #3
Mongler98
Not anymore unfortunate.
Fortunay other than setting the odometer, they can be repaired with just a few tools including a soldering iron.
Get a temp controlled soldering stick and practice. It's not too difficult.
I do have one from my Jetta, not sure if they are I interchangeable.
Old May 27th, 2020, 11:02   #4
TDI Jim
I get mine repaired with Derek White, Chubb's Auto Repair, Taylorville, IL
TDI Jim is offline   Reply With Quote
Old May 27th, 2020, 22:17   #5
Steve Addy
TDI(s): 97 Mk3
Derek is done also, and I believe that Chubb's has closed down, at least according to Mark it has.
Steve
the magic triangle spins in the peanut and then apex seals come out
Strava
Old May 28th, 2020, 05:12   #6
Abacus
That helpful B4 guy
Abacus's Avatar
Fuel Economy: And the miles just keep ticking away
The person who bought Derek's cluster repair equipment is not up and running yet, unfortunately. I do not know when that will be, but their intent is to pick up where Derek left off.
'97 B4: 453,000 miles FOR SALE! Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
'96 B4V: 356,000 miles Malone 2+, PP520's, 6 speed, 02J short shifter, E-Codes, G60 brakes, Evo plate, DMF, stainless exhaust, heated leathers, cold weather package
BUG*PWR 2013 Award Winner
Abacus is online now   Reply With Quote
Old Yesterday, 03:25   #7
C_Free
Thanks for the suggestions. This from the cluster tech:
We did look at your unit and found it had correlated issues with a failing microprocessor which means it has data hardware issues we weren't able to repair. Normally this particular type of cluster suffers from blown diodes that cause physical damage to the board that we can address and repair but your cluster had no noticeable physical damage paritc9iulary in that area or anywhere else for that matter. Everything pointed to a bad processor which is why we refunded.
Given my lack of component electronics repair skills, It is better for me to have it repaired/find a replacement.
I will keep looking for a replacement.
It's too bad, this car is pretty cherry and runs great otherwise!
leider geil!
Old Yesterday, 07:15   #8
Abacus
That helpful B4 guy
Abacus's Avatar
Keep the other one for when it can be repaired, or for parts for a swap.
Changing the instrument cluster to the MFA cluster pkhoury VW MKIV-A4 TDIs (VE and PD) 4 May 27th, 2016 12:13
Jetta 5 2.0TDI beeping instrument cluster and flashing cluster lights. HELP PLEASE!!! B40RK@D VW MKV-A5 Golf/Jettas 9 January 24th, 2016 19:58
Instrument panel woes Deeslbricher TDI 101 7 February 6th, 2010 12:10
Instrument panel woes. Pleas help. gebbeth VW MKIV-A4 TDIs (VE and PD) 2 November 14th, 2008 08:05
Instrument Cluster mileage adustment woes... JMan VW MKIV-A4 TDIs (VE and PD) 1 December 16th, 2005 15:31
Page generated in 0.14169 seconds with 12 queries
[Output: 87.02 Kb. compressed to 75.16 Kb. by saving 11.86 Kb. (13.63%)]
