I was tired of only having the fog lights as DRLs and really missed having my LED DRLs on since coding Byte 18 to 53 or 55. It appears that there are very few Byte 18 codings that provides the proper voltages to the rear LED's - LED center bullets with 0 VDC except when braking. So I started to experiment with some old codes that I tried before and went up as far as I could.
Found a new site, sent by a fellow TDIer. Check it out:
http://www.partsbase.org
It is self explanatory, and cross references any part with all other variants in the world. It is not only VW, but many others. I looked up my BCM, and then found that it is also installed in Tiguans and CC's. My CC schematic had a different BCM, so that was a non-starter. I had a Tiggy schematic, and got interested that it had DRL's on pins 52a-7 & 8. Looked at mine and there was no pins in these locations. So that got me to start coding again.
97 - was promising, had the rear LED bullets lighting only on brake, the rest was dim, but the LED DRLs were not working. When I first tried this combo, I noted that the DRLs were working. Bummed.
I tried everything sequentially up from 97 to 9F, A0 (stock) to AF, B0 to BF, CO - C7, D0, E0, F0 and quit.
From C0 up, all lights are on. I mean all - brake, amber turn, reverse, front lights, etc, on at once, no control with switch or brake lights. Looks as if anything above C0 is not programmed.
Promising was B0, but requires swapping some wires at BCM, similar to the Golfs. This gave the LF DRL and LR reverse light on as DRL's. Driving lights was all rear LEDs (incl bullets) on dim, brakes was full 12 V and bright. Reverse only gave the RR reverse lamp, so this could be cross wired to the LR reverse (for 2 reverse lights) after making the existing LR reverse wire the rear fog lamp. The current configuration (with rear fog relay) resulted in a bulb out warning (for no rear fog connected to BCM), when triggering the rear fog input to the BCM. The current LR reverse BCM wire (at 52a/28) needs to be removed and taped off. The RF DRL (at 52c/47) needs to be moved to this location. The rear fog is then connected to 52c/47. One could use the LR reverse wire for the rear fog, but since I already have a new wire run, it would be easier for me to relocate it from the relay I installed and activate the rear fog through the BCM.
So I wasn't into swapping wires today, and looking over my previous notes on byte 18 changes, I coded Byte 18 to 7E. This gave me back the LED DRLs. The amber turns all work. Both reverse work. The only thing is that the eyebrows, ring and bullets are lit as the driving lights (dim at 3.3 VDC). Brake is bright (12 VDC) on all three circuits - eyebrow, ring and bullet. I will ponder this a bit more, as a fix for the bullet off except for braking will also apply to B0 coding for Byte 18. Sorry no new pics today on this.
