Old September 16th, 2014, 12:46   #1
JETaah
Default DSG on red ATF
A customer brought in his car today for DSG fluid service.
What drained out of the trans looks to be conventional ATF red fluid.
Anyone know of a DSG fluid that even approaches having a reddish color? I don't.
The owner said it was changed about a year ago and does not know what was used.
When I drove the car prior to the change I did not notice anything funny about the operation of the trans...and no complaints from him about it.
Anyone know for sure what the consequences are from doing this?
Old September 16th, 2014, 15:00   #2
jaymzaugust
TDI(s): 2009 Jetta
The stock VW/Audi DSG fluid is red/pinkish. The liquimoly equivalent is a gold/tan color.
Edit: WRONG. See oilhammer's post below.
jaymzaugust is offline   Reply With Quote
Old September 16th, 2014, 15:24   #3
oilhammer's Avatar
Fuel Economy: fantastic
No it isn't. DSG ATF tt is light amber, looks like motor oil, always has. It has a distinct smell, somewhat pleasant actually.
This is why it is so important to verify the correct ATF, since VAG uses so many different transmissions and different fluids. And this is also why I hate it when people say "Tiptronic" since that means nothing.
www.cardocautomotive.com
Old September 16th, 2014, 15:35   #4
meerschm
meerschm's Avatar
so does this customer put 40 k miles a year on?
I do not think you drain all the fluid out for a change, there is fluid in places that does not just drain out.
if it was my car, i would consider changing again in a month or so, and then move on.
there are, I think, some friction modifiers specific to the fluid for the clutches. somewhat similar to the stuff they put in transfer cases. has to lubricate, but not too much.
I only have seen fluid from my car, but it is as oilhammer says.
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old September 16th, 2014, 16:08   #5
JETaah
That's the plan.
Old September 16th, 2014, 17:02   #6
JETaah
Is ATF sufficient for a final drive?
Old September 17th, 2014, 08:00   #7
jaymzaugust
TDI(s): 2009 Jetta
Oh great... well whatever it was I drained out of my 2009 at 80,000 miles was red. I wiped the filter housing out with white paper towels, definitely red fluid. The 40k service was performed by the dealer. I wonder what sort of koolaid they filled it with. Sorry for the misinformation, I'll go back and edit my original post.
ATF cooler leaking ATF fluid AlanTDI TDI 101 1 July 7th, 2013 12:06
New 09 JETTA TDI RED DSG Jettawolfs98 Jetta/Bora/Vento TDI Picture Gallery 20 February 14th, 2012 10:14
FS 2006 TDI DSG Red jon.zaimes TDI Cars for Sale/Wanted 2 July 16th, 2009 23:48
Check ATF level on DSG trans??? soberups Fuels & Lubricants 15 November 27th, 2006 14:57
Synthetic ATF -VS- VW ATF - what 's the diff? enatman VW MKIV-A4 TDIs (VE and PD) 12 October 13th, 2005 13:27
Page generated in 0.12993 seconds with 13 queries
[Output: 82.92 Kb. compressed to 71.87 Kb. by saving 11.05 Kb. (13.33%)]
