couple points to clarify.
the oil ash volume does increase about a ml per thousand miles, but only does so by values of 7-9 ml. if you look at the reported values, they are discrete. (mine recently went from 189 to 198)
it is not obvious that they use pressure at all in calculation of the values. there seems to be some variability, so some adjustment is made for differing use, but it is far from clear what those adjustments are. until someone dives into the software, we do not really know.
The companies that clean DPFs do not have to cut them apart. they use heat and compressed air to convert any remaining oily/sooty residue to ash and blow it out of the part.
http://forums.tdiclub.com/showpost.php?p=4811559&postcount=22
Three points:
1) Good to know it reads in 7-9 ml increments on RossTech cable, but the
average is 1ml per 1000 miles regardless.
2) I am sure there are folks that claim to clean DPF with it assembled. How
effective, I don't have much faith. As you show they can crack internally.
There are companies that cut them open and re-weld (or use to). The
cleaning of the honeycomb structure will be far better, not really a debate.
You can buy your own chemicals or DPF kits, and use a pressure washer
yourself without sending it to a company (shipping to and from). Cost of
new verses cleaning and old one, is not enough to be worth it in my opinion.
3) I plotted out the data and the correlation of oil ash load to mileage, is
excellent. Using "numerical methods" I can write an equation to *estimate*
Ash Oil = 1ml/1000 x miles (very linear)
It makes sense delta pressure might be used. EGT before and after may be
a factor too? Does it look at mass air, torque, fuel flow? I don't know or care.
I am sure mileage adds ash oil like an odometer. I would think delta pressure
is a factor (may be not). It's an estimate value calculated by indirect measurements
(mileage, delta P, delta EGT, full moon). The exact solution or formula is proprietary,
but I am sure it is not that sophisticated.
