skiaspeblu
During repair, ecm cover was accidently touched with battery plus. Since that car will crank but not start. Also if key stays on in the car after trial to start radiator fan start
in high speed. Car was checked . All fuses ok, all relays ok. I scanned with VAG and received the following info
17-Instruments -- Status: MalfunctioVCDS Version: Release 12.12.0
Data version: 20130910
Wednesday,04,January,2017,08:29:38:62939
Chassis Type: AJ (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VWWL7AJXEM414387
01-Engine -- Status: Malfunction 1110
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
n 0010
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: A14B400C492300FE850E02EC92200042A1100010
Shop #: WSC 00066 000 00000
VCID: 7EF31873E902AEEEE6F-802B
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 251
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:08:27
Freeze Frame:
Count: 2
Count: 0
Count: 20992
Count: 8194
Count: 40704
Count: 0
Count: 259
Count: 0
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 J HW: 5C0 937 087 A
Component: BCM25 JLB H3 H34 0411
Revision: B2034001 Serial number: 08013023140328
Coding: 7B994B9A08230F0008382000240884C50082502E60000000300010002000
VCID: 3467FA5B97CEB4BE40B-8061
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Coding: 800000
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:12:25
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:11:25
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD037H3D
Coding: 00004138
Shop #: WSC 00066 790 07027
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360_VW01.rod
VCID: 74E73A5BDF4EF4BE80B-8021
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y1400011J7T0T
Coding: 303053
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME42124E40ZZZO
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME4D041D41ZZZY
Crash sensor for side airbag; rear driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME0F4F3D2AZZZ8
Crash sensor for side airbag; rear passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME40681429ZZZO
Crash sensor for front airbag; driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME5B3B7924ZZZ3
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME61144F2AZZZ
3 Faults Found:
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 60169 km
Date: 2023.14.01
Time: 00:00:16
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:47
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:03
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5C6 920 853 A HW: 5C6 920 853 A
Component: KOMBI H04 0809
Serial number: 00000000000000
Coding: 370E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 2A5BE4234D0AF24EEA7-807F
2 Faults Found:
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 251
Mileage: 60169 km
Date: 2023.14.01
Time: 00:08:27
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:25
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H34 0411
Revision: B2034001
Coding: 102200
VCID: F0EFB64B2356489EE43-80A5
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 251
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:08:27
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 251
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:00:00
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0809
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
No fault code found.
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3979CB6F70AC49D693D-806C
2 Faults Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:08:26
Freeze Frame:
Battery Volts: 11.6 V
DU
Temperature: 12.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 251
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:08:27
Freeze Frame:
Voltage: 11.50 V
DU
Temperature: 12.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H03 0006
Revision: -----07S Serial number: VWZ4Z6P3723070
Coding: 01000400020006
VCID: 2345090722202306A91-8076
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:12:31
Address 77: Telephone (J412) Labels: None
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665454899
Coding: 0310030080010110
Shop #: WSC 47290 001 1048576
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI_VW25.rod
VCID: 2E53E83371E29E6E36F-807B
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:18
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:18
End ---------------------------------------------------------------------
Just wonder if anybody experienced such case like that. Since that ecm will not communicate either. From autoscan probably could be concluded that abs module and power steering assisted module gone, not sure about can gateway j533 and also ecm module gone. I like to have second opinion before I will replace those parts which take lots of effort to change.
I will appreciate any help
n 0010
Address 01: Engine
Cannot be reached
Revision: 00H46001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 251
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:08:27
Freeze Frame:
Count: 2
Count: 0
Count: 20992
Count: 8194
Count: 40704
Count: 0
Count: 259
Count: 0
Cannot be reached
Coding: 820000
Coding: 820000
Coding: 180000
Coding: 020000
Coding: 800000
Coding: 800000
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:12:25
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:11:25
Coding: 00004138
Coding: 303053
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 60169 km
Date: 2023.14.01
Time: 00:00:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:47
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:03
Coding: 370E00
2 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 251
Mileage: 60169 km
Date: 2023.14.01
Time: 00:08:27
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:25
Revision: B2034001
Coding: 102200
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 251
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:08:27
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 251
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:00:00
Serial number:
Coding: 000000
Cannot be reached
Revision: 00H22000
2 Faults Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:08:26
Freeze Frame:
DU
Temperature: 12.0°C
Count: 2
Count: 0
SteerAng n.Init
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 251
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:08:27
Freeze Frame:
Voltage: 11.50 V
DU
Temperature: 12.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Time Indication: 0
Date: 2023.14.01
Time: 00:12:31
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:18
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 36
Mileage: 60169 km
Date: 2023.14.01
Time: 00:11:18
