So it all started with the power steering line blowing out while I was a long way from home. Drive the car back while allowing the power steering to run dry for 2-3 hours and park it on the street.
A few days later, start it up to get it another 40 feet into the garage and the belt goes.... car stalls.
So.... It'd due for a timing belt anyways, I tear the whole car apart, and goto manually crank it to TDC and... *clink*... it won't crank.
So I'm thinking that in busting the serpentine belt I made the car skip a tooth or something.. at which point it instantly stalled and some neighbours helped me push it into the garage.
Here are the questions:
1) How is it possible that I lost the timing by snapping the serpentine belt?
2) I'm pretty sure I need to pull the head and check for valve damage, right?
2) Is a head rebuild beyond the DIY pay grade? Background readying suggests once I get it off, assessing the damage will not be that straightforward, so should I be looking at a professional rebuild, or is it simply a matter of buying a rebuild kit, those little spring compressors, and swoping out valves?
