Growler
Got Soot Vendor
- Joined
- Nov 24, 2003
- Location
- Millersport, Ohio
- TDI
- Schmutz, 2015 Golf Sportwagen DSG & Schnurren, 2001 Golf GL 2 door 5M
I installed one of these MK2 high temp thermostats today. VCDS says on a 20 mile loop to work & back, got up to 93.2C so it seems to be working properly.Originally Posted by josh8loop View Post
Just for informational purposes, if someone wanted to replace their thermostat and didn't want to experiment with the "Hybrid" construction method, and good second choice might be:
http://www.autopartswarehouse.com/sk...&+Drivetrain
That would give you 197.6 deg F (92 Deg C). This is the highest direct fit type that I have found for the ALH engine. Most replacement T-stats from Wahler and other OEM brands seem to only go to 87 Deg C(188.6 Deg F) The Behr unit mentioned above seems to be of a good sturdy construction, and may possibly out last Stant types FWIW.
THanks for the idea guys. Ill keep an eye on my mileage. I am hoping to improve my poor mileage.
aaron
