Aljefanfrey
First post, been using for years.
I have an 03 ALH thats been down for a few months (stuck glow plug, couldnt salvage the head). Went ahead and rebuilt the turbo while it was out and decarbonized the intake components (couldnt fit my pinky inside it due to build up....). Swapped everything over and reassembled and now i have no boost.
I verified vacuum hoses.
I pulled apart all the intake components and cleaned them and cant find a boost leak.
Pulled around a liter of oil from the bottom of the intercooler
Turbo rotates freely and while i had the parts off, i verified that its actually push air through (although not much)
VCDS actual boost starts around 1000mbar and decreases to maybe 800 as the engine uses the air.
Turbo does rotate and blow, but you cant hear it like normal when driving, and its completely gutless.
I have vcds but this is the first time ive been stumped.
Any help is appreciated.
