Gorpher
It seems like it is something new every month with the car now. 2000 TDI with 285k. It has been parked for a few weeks after the latest episode, just because I simply haven't had the time or money to start messing with it. Now I need to figure it out.
THe car was driving fine. All suspension has been replaced since Christmas. On my way into work a few weeks ago and decided to stop at Tim Hortons. I go into the drive thru an wait in line. When it is my turn to move up the car shudders badly and stalls. I was a bit embarrassed thinking that I popped the clutch too soon and stalled it. The car started right back up. Went to move forward again and same thing. It felt like the tires would rotate just slightly and then the shudder and stall. It felt almost as if the tires were locked in place...hard to explain. I decided to try to back it up to:
A-Get out of the line which I was now holding up
B-See if if would move backwards
I was able to back it up and park in a spot in the drive thru. I looked under the car and saw nothing out of the ordinary, but I cant see much with the steel skid plate there anyway. I talked to a friend from the forum who said it may be a failed Dual mass flywheel (?). I searched the DMF but haven't found any threads with similar situations to mine. So, the car was towed home and is currently sitting in the driveway.
I need help diagnosing the problem so I can fix it. Any suggestions would be greatly appreciated.
Robb
Robb
