turbo technical database
[486]
MN
02 golf ALH
why do sequential when I can do straight compounds? Whole reason I went with compounds is to get the breathing there without needing to buy a camshaft.
What PR is your LPT pushing ?
And how many milles did your HPT last ?
LP is making 25 PSI, HP bumps that up to 45
iirc the interstage WG is sprung for around a PR of 2? Just the thrust load with the increased airmass is too much.
Got maybe 10k out of the old bearings in the turbo, haven't checked on the new set yet, but they've got about another 10k on them. Got a VF27 on the shelf, just gotta get it jammed on there, after the insight swap is running... Ugh, projects.
ibizatdi130
FRANCE
SEAT Ibiza ASZ tdi 130- SEAT leon bkd tdi 140
It would be best to go with a more modern turbo and at the minimum, I'd go with either a GTB1756VK or GTB2260VK depending on what mods you have done to your TDI.
IMO, I'd go with the most current turbo you can buy for the best performance you can get out of a turbo and that would mean going with either a GTD1752VRK/GTD1756VRK or the larger GTD2060VZK.
Here are a few GTD1752VRK/GTD1756VRK options:
https://www.mecevo.com/parts/garrett_turbo_gtd1756vrk_with_77_billet_wheel.html
https://gottuned.com/product/gtd175...m-converted-and-welded-onto-stock-1-9-2-0tdi/
If you wanna upgrade to a GTD2060VZ, it will require quite a bit of customization to make it work on a 1.9L TDI.
I will soon use a gtd1756vrk on my BKD because I have stock injectors so I don't need bigger turbo, but I think using gtd1756vrk with sotck manifold is not good, actualy I use gtb1756vk mfs, before I was using it with stock manifold and now with 4 in 1 tubular manifold and there is a big difference at low rpm, now no surge and spool realy quikly.
I realy think that my old gtb1756vk with tubular manifold is better than gtd1756vrk with stock manifold. stock manifold has realy bad flow
JST
The Netherlands
Alfa Romeo Giulia 2.2 jtd 180 AT8
Garrett 856473-0001
GTD1752MVKR
Alfa Romeo Giulia / Stelvio 2.2 JTD 180 hp
Ceramic ball bearings
Compressor billet 8 full blades with ext tip, 37.2/52/53.7
Turbine 11 blades 39.5/43
Power potential 240-250 hp, 500 Nm at 1750 rpm at full stock engine.
Also available with rpm sensor, for the 2.2 jtd 210 hp, 853741-5004s.
TDIMeister
Canada
Still slightly bigger than the BMW's 36mm, so that's good. Can't yet tell from pictures online whether it is integrated with the exhaust manifold or separate.
Syncrogreg
Nashville TN
2.0 TDI CR SWAP ALWAYS FOR SALE
I have this bad boy going on the CUAA TDI. I hope to have all the boost from 2800rpm to 5000rpm is what we need.
Temperature capable 1050C
G25-550
Talk soon!
Rub87
Belgium
Ibiza '99 90HP
Engine aint 1050 deg capable ����
Maybe mount into vnt housing?
JST
The Netherlands
same comp iducer this 210hp verson? plenty power for 37mm...
Yes same wheel size for 210 version, only difference is the rpm sensor.
This unit does 3200 mbar on a stock 2143cc engine, quite amazing for a turbo of this size.
I will test this turbo with a GTD2056vzk comp wheel soon. Let's see if we can reach 3400 mbar...
Unfortenately integrated, here's a better photo:
Jukums
Latvia
1.9 TDI 1Z TDR.lv
So information about turbo
GT3067s WG
CW - billet
In 49.6mm
Ex 67.5mm
Extended tip 70mm
Housing A/R 0.60
TW
In 59.5mm
Ex 50.5mm
Edit - Housing A/R 0.56
It has billet compressor wheel, anti-surge, water cooled CHRA.
It comes on 2013 Audi A7 3.0d Bitturbo 230kw
And here is result of this turbo on 1.9TDI, need to do some work to get stable boost.
https://youtu.be/erf10pcTmOA
ryanp
Barnsley, South Yorkshire, UK
Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
Nekit
Indiana
2013 A3 TDI
Does anyone know where I can get the exhaust flange for the turbo downpipe, or what its dimensions are? Making a custom exhaust for a conversion project. Using CJAA engine with CR140 turbo. Thanks
02TDI_sam
Monroe, NC
2002 TDI Golf
I have not seen the specs for a KKK turbo from a 1983 Mercedes 300d. It is wastegate and was thinking of trying to use it on my 02 golf ALH. It is much bigger than the stock vnt15... Is there any advantages/disadvantages to using a wg turbo on my ALH.
[486]
MN
02 golf ALH
ehhh, basically anything's an improvement over the stock ALH turbo
Ain't those k27s? 5.9 cummins guys seem to really like them
you'll need more injector to get it to light up
sMh
Romania
ALH ve90
Hi guys, I just wonder, why nobody talks about bmw e39 525d 2052v turbo, to me it seems to fit much more easily on transverse tdi's than bigger brother from vag v6 2.5 tdi.
I want to put the gt2052v e39 m57 turbo in my ALH but can't find any info about it. Maybe you guys can help me with some info. Thanks and have a nice day!!!
adamss24
Great Britain
audi a4 2.5 tdi 98 quatrro 6speed
Hi guys, anyone have specs for turbocharger fitted on range rover 2.7 tdi engines ? It's a KKK vnt turbo with electronic actuator, seems to have a similar manifold flange as bmw or transporter t4...I want to use it on a t4 van just not sure its worth it over a gtb turbo... Size wise its slightly larger than a bv43 but i never judge potency of a turbo by size alone...
link: https://en.turbolader.net/Turbocharger-Catalogue/8900-2768/LR021042/53049880115.aspx
TDIMeister
Canada
Looks like a BV50, so comparable to a GTx20 frame size class. Based on the original engines' power outputs, I consider them highly unremarkable and if performance is what you're after, look for a turbo whose original application is producing north of 260 HP not just 190 in the Land Rover.
https://www.turbomaster.info/eng/applications/passenger_cars/land+rover/3K/
Edit: eg.
https://www.ebay.com/itm/264259783330
(no connection to the seller)
https://www.turbomaster.info/eng/applications/passenger_cars/audi/ (recommend limiting your searches to the GTD20xx PNs).
adamss24
Great Britain
Thanks ! It was just an idea to maybe use it on the t4 transporter i have...at 1st glance it looks like it would bolt on the stock exhaust manifold...I need to build a tubular manifold in order to use a gtb2260vk on the van, not enough room unless i bring the turbo over the engine...
racediesel
Finland
BMW 530D
Hello
I am intrested of BMW F11 535xd 2012 313ps model turbocharger turbine and compressor diameters, basicly big one?.
and of course how much pumping air (airmap?) and how much can get with that horsepower if fuel have nough.
maximum boost pressure?
Greetings
Racediesel
FRtdilover
europe
2001 4motion ARL 150
Few pics of this one
Gtc1446vz from 2.0d Volvo V60 (Volvo 31312712 Garrett 790367)
Specs :
Stock vacuum operated
CW : 34,1mm inducer / 46mm exducer
The housing has a 3" inlet
Kind of anti surge groove (MWE ?)
No billet wheel but gtd1446vz has billet wheel (Volvo 31380131 Garrett 836265)
TW : 34,5mm exducer / 39mm inducer
A/R 0.74
I'll try this one in a compound setup and a friend of mine is planning to use one as a single into his 1.4 tdi
FRtdilover
europe
Yep it's quite the same unit in terms of design and technology. Only the CW is a bit different, but it should work just as great as yours
Overall dimensions are 26cm/10" height , 20cm/8" length , 20cm/8" width
Vband size is 77mm OD and 50mm ID
I guess I'd need to machine a custom Vband exhaust flange, right ? Did you use the Volvo oem Vband clamp and gasket ?
