So I managed to backtrack those images to your pics account on the forums and look at the less-lossy JPEGs. I have mirrored the imaged on my server and if you click the code you'll be shown the graphs he posted.
Stock Cam
Code:
Date of Pull: May 3rd, 2012 @ 12:11
Peak Trq: 319 ft*lbs Avg Trq: 277 ft*lbs
Peak whp: 194 Avg whp: 165
RPM Range: 2000-4200
Almanac Data
Low: 59°F
Mean: 68.7°F
High: 79°F
Press.: 29.79"
Colt Cam
Code:
Date of Pull: September 20th, 2012 @ 13:08
Peak Trq: 310 ft*lbs Avg Trq: 242 ft*lbs
Peak whp: 198 Avg whp: 144
RPM Range: 1600-4400
Almanac Data
Low: 50°F
Mean: 57.4°F
High: 66°F
Press.: 29.87"
darkhorse, your dynos have some validity, but they're less applicable than what we're going for, mostly because they're for a PD engine not the VE engines, aka commonly the 1Z and ALH, which is what we'll be testing it against. They're also done months apart thus unstrapped from the dyno. This has been noted in long standing to cause variations in the results.
Here is ValiPowder's old chart comparing the 3 with basic profiles:
TDIMeister's data:
In other news, I have an updated tune from my tuner correcting a couple of things and prepping for the dyno day. Small stuff that I've adjusted my right foot for, but will cause variations in the dyno.
I'll need to check with him again to see if he can adjust the MAF to where we can pull applicable data from it, though asking about adjusted tune for the cams, he's in the same ball park as I to where the effect of the cams should be done with 1 tune and see what the output changes are. Yes, EGTs and smoke typically go down, but making them go back up again to account for the better breathing is just another perspective on the same data.
Just so you guys know, and I'll produce the procedure used when all of the data is collected, I'll be keeping the same lifters that I installed in the car 20K miles ago and the shop does have a WBO2 sensor available. Localized weather collections of temperature, relative humidity, and barometric pressure will be done for each dyno run along with other data logging, which still needs sorting.
I'm also waiting on a replacement socket for my burner because a pin became irreparably damaged and I cannot burn the new tune
. I might have a surprise on the dyno day too, but I'm not sure of the specifics just yet so I'm keeping quiet. Yeah, this is a tease, deal with it.
