Well I am not having much joy with this turbo at all. It has been on and off the car 3 times over the last few months. The problem is the turbo is using oil, at around 12-1600 RPM when driving you get plumes of blue smoke out of the back of the car. It's fine at higher revs but normal driving it's no good. The original GTB2260VK has 2 turbine oil seals, the AMG only 1 . You would have thought that as on the original car it worked fine with 1 ring why would it not on my car.
Anyway the turbo was returned and they installed a second ring however it had to be located next to the first as there was no room to install a second slot. apparently they used to do this with T3 /T4 turbos.
This was a slight improvement , but next I replaced the DPF/ cat that had been gutted and was thought to be causing the problem due to the lack of back pressure.
After replacing this it still smokes.
This was the gutted DPF that was on the car it does look a bit like a 2 stroke expansion chamber .
Heres a video of the smoke produced by the turbo now.
Anybody have any idea whats going on here. There are loads of A4 and A5 cars driving around in Europe with this turbo mod on and I am sure they aren't doing it with plumes of smoke out of the back.
Karl.
