06SpiceRedTDI
- Joined
- Jun 12, 2006
- Location
- Longview, WA
- TDI
- 2006 Spice Red TDI Jetta, 2006.5 DSG Platinum Gray TDI
So what I gather from all of the data that I have been reading here is that the clutch used in the MKV is the same clutch that was designed for the ALH motor in an MKIV which is only rated at 155 ft/lbs of torque, and the actual max torque rating on these clutch is 170 ft/lbs. So the real reason that there is so many clutches going out is the fact that the max torque rating of the clutch is actually exceeded by the PD100 in our cars which is rated at 177 ft/lbs. of torque throw in a heavier car than this clutch was designed for and you have a recipe for disaster.
