Yourbuddysatin
Thanks red16vdub. Makes me feel better on that expensive purchase.
why?This car will be lucky to see 20k after I’m done.
Do you know the numbers for the ASZ engine? I will indicate that the head is differentKit #: 204-4706 for the head studs
Kit #: 204-5408 for the main studs (1.8t are the same as the 1.9)
They’re not even made out of the same material as a VW head.Totally disagree with you on the AMC Alh Tdi replacement head. I had a lifter come apart in one of my tdi’s, it destroyed a piston and head obviously. AMC was purchase new, which is well over a 100k miles and counting, on stage4 rc @ 28psi .
I also know of another person with roughly 68,000 on stg3 rc with AMC head .
When my OEM head let go, 2 Tdi guru’s gave the recommendations.
