mishkaya
TDIClub Contributor
It looks like it's time for me to start a thread. I have a no start situation on my 2010 JSW after sitting for a month or so. Car had a battery tender hooked up. When I turn the key on the ignition, nothing happens, it's as if the clutch interlock switch were not working.
VCDS scan shows a few codes for the central electronics however, and I think that is where I need to start looking, but I am at a bit of a loss as to where to start, and was hoping for some assistance. VCDS log follows:
Sunday,15,March,2020,12:44:20:41177
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4513.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: 3VWPL7AJ7AM629109 License Plate:
Mileage: 297130km-184628mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ7AM629109 Mileage: 297130km-184628miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
Component: R4 2,0L EDC G000SG 7966
Revision: 12H02--- Serial number:
Coding: 0050072
Shop #: WSC 07325 444 84734
VCID: 77BE2B85066D9DF796-8022
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 114B600C49240003880C06E4922200423000
Shop #: WSC 00066 000 00000
VCID: 7EB03EA1E957ACBFD5-802A
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 N HW: 3C8 907 336 N
Component: Climatic H13 0203
Revision: 00006001
Coding: 0000000000
Shop #: WSC 00066 000 00187
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: 383CE8B983F3528F5F-806C
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 C HW: 5K0 937 085 C
Component: BCM PQ35 B++ 008 3019
Revision: BI008001
Coding: 27380EB8802D3EC4000800014000000007000000435D8560640000000000
Shop #: WSC 25807 444 68371
VCID: 3326DF959295B1D76A-8066
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 26100 21 0501
Coding: 009795
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 254
Reset counter: 10
Mileage: 297137 km
Time Indication: 0
Date: 2014.06.25
Time: 22:50:09
Freeze Frame:
Term 15 Off
Voltage: 16.60 V
OFF
OFF
OFF
OFF
OFF
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 10
Mileage: 297137 km
Time Indication: 0
Date: 2014.06.25
Time: 22:50:09
Freeze Frame:
Term 15 Off
Voltage: 14.10 V
OFF
OFF
OFF
OFF
OFF
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 50
Mileage: 297137 km
Time Indication: 0
Date: 2014.06.25
Time: 22:50:03
Freeze Frame:
Term 15 Off
Voltage: 11.25 V
OFF
OFF
OFF
OFF
OFF
01516 - Terminal 30; Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 10
Mileage: 297137 km
Time Indication: 0
Date: 2014.06.25
Time: 22:50:09
Freeze Frame:
Term 15 Off
Voltage: 13.85 V
OFF
OFF
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 019 0706
Serial number: 003C4D07BP3Z
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 393AEDBDB8F94B87A0-806C
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0004SLDM00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1A23614AZZZU
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME0D21104AZZZP
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME6908381DZZZT
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME3D574B1DZZZ$
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME6601711CZZZA
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME1917711CZZZG
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000732
VCID: 78BC28B90B73928F9F-802C
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 970 L HW: 5K0 920 970 L
Component: KOMBI H08 0021
Revision: V0008011 Serial number:
Coding: 271C00
Shop #: WSC 00066 123 00146
ASAM Dataset: EV_KombiUDSMM9RM10 A04010
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 373EEB858EED5DF756-8062
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 080909F2000406
Coding: E9807F06001602002002
Shop #: WSC 00066 123 12345
VCID: 668076C151C7147F3D-8032
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T620D04
Coding: 0000002
VCID: 7EB03EA12957ACBFD5-802A
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H08 0021
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
ROD: EV_ImmoUDSMM9RM10_VW12.rod
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1525
Revision: 72009005 Serial number: 00000895899001
Coding: 0001205
VCID: 6FAE13E57E3DD5374E-803A
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Reset counter: 49
Mileage: 0 km
Time Indication: 0
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 70 2901
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 2F2ED3E5BEBD95370E-807A
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1525
Revision: 72009005 Serial number: 09071715043701
Coding: 0001204
VCID: 70AC10996303CACF57-8024
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Freeze Frame:
Fault Priority: 3
Reset counter: 50
Mileage: 240172 km
Time Indication: 0
Date: 2011.05.01
Time: 17:08:04
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Reset counter: 50
Mileage: 240172 km
Time Indication: 0
Date: 2011.05.01
Time: 17:08:04
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H07 0009
Revision: -----12S Serial number: VWZ4Z7P3560427
Coding: 01000400040007
VCID: 2B16C7F54AA5E91722-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 5
Reset counter: 9
Mileage: 294625 km
Time Indication: 0
Date: 2014.01.29
Time: 10:09:50
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000004360078
Coding: 0001168
VCID: 76A026810167E4FF8D-8022
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000004336325
Coding: 0001168
2 Faults Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
Freeze Frame:
Fault Priority: 3
Reset counter: 50
Mileage: 240172 km
Time Indication: 0
Date: 2011.05.01
Time: 17:07:60
01554 - Motors for Central Locking; Rear Doors; Lock
Freeze Frame:
Fault Status: 01111100
Fault Priority: 3
Fault Frequency: 26
Reset counter: 10
Mileage: 240172 km
Time Indication: 0
Date: 2011.05.01
Time: 17:07:59
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664737170
Coding: 0A01040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A38F2B1BDFF409FA9-806E
1 Fault Found:
13636608 - Control Module Incorrectly Coded
U1014 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 10
Mileage: 297137 km
Date: 2020.03.15
Time: 12:50:10
End----------(Elapsed Time: 01:17, VBatt start/end: 12.1V/12.3V)-----------
www.Ross-Tech.com
Coding: 0050072
Revision: 00H45001
Revision: 00006001
Coding: 0000000000
Revision: BI008001
Coding: 009795
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 10
Mileage: 297137 km
Time Indication: 0
Date: 2014.06.25
Time: 22:50:09
Freeze Frame:
Term 15 Off
Voltage: 16.60 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 10
Mileage: 297137 km
Time Indication: 0
Date: 2014.06.25
Time: 22:50:09
Freeze Frame:
Term 15 Off
Voltage: 14.10 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 50
Mileage: 297137 km
Time Indication: 0
Date: 2014.06.25
Time: 22:50:03
Freeze Frame:
Term 15 Off
Voltage: 11.25 V
OFF
OFF
OFF
OFF
OFF
011 - Open Circuit
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 10
Mileage: 297137 km
Time Indication: 0
Date: 2014.06.25
Time: 22:50:09
Freeze Frame:
Term 15 Off
Voltage: 13.85 V
OFF
OFF
OFF
OFF
OFF
Coding: 00003044
Coding: 0000732
Coding: 00000130
Shop #: WSC 00000
Coding: 271C00
Coding: 0000002
Coding: 0001205
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 49
Mileage: 0 km
Time Indication: 0
Revision: 00H17000
Coding: 0001204
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 50
Mileage: 240172 km
Time Indication: 0
Date: 2011.05.01
Time: 17:08:04
Freeze Frame:
Fault Priority: 3
Reset counter: 50
Mileage: 240172 km
Time Indication: 0
Date: 2011.05.01
Time: 17:08:04
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 9
Mileage: 294625 km
Time Indication: 0
Date: 2014.01.29
Time: 10:09:50
Coding: 0001168
Coding: 0001168
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 50
Mileage: 240172 km
Time Indication: 0
Date: 2011.05.01
Time: 17:07:60
Freeze Frame:
Fault Priority: 3
Fault Frequency: 26
Reset counter: 10
Mileage: 240172 km
Time Indication: 0
Date: 2011.05.01
Time: 17:07:59
1 Fault Found:
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 10
Mileage: 297137 km
Date: 2020.03.15
Time: 12:50:10
