systematdi
Was checking out why my AC has not been functioning as of late, found no fault codes stored on the HVAC. There is no pressure change on the low / high side. I also noticed that the shaft of the AC compressor is not spinning.
Is it correct to state that they're NO clutch on these units?
I am assuming the pump locked up and spun the pulley off the safety tabs? OR ?
thanks.
thanks.
