I am switching back to the original injectors body and all. The .216 smoke to much and my fuel mileage is only at 35mpg. I really don't think all that raw fuel is good for the turbo I may be wrong I'm not much of a diesel guy. I do have vcds lite maybe I can adjust something that would help but I don't know. Thanks guys
#1 thing you always do is fix the stock parts before you go powering things up.
i dont think your TDI is running very good and might have some timing, clogging, and head work necessary. How many miles? i bet you that your cam is a bit worn and your turbo and intake might be glogged up, very common for a MPG robber.
I would t ry a few tricks first before you go backwards. 520's are fine nozzles and you should be getting 45 to 50 EASILY, my pp764's on the stock turbo (for the small time it lasted) got 47mpg from the 40 it used to get and that was no tune, nothing other than the nozzles and a few bolt ons. once i upped my intercooler and turbo i was able to get into the 50's.
there is no reason with a little bit of work here and there and maybe a few $hundred bucks you could make it into the 55mpg club.
FIRST off, what is the QA set at? bump it way up to like 6 to 7, i bet you have it down in the 2-3 or less area.
2nd, UP YOUR BOOST. your stock turbo can put out a tiny bit more but the best way to go about this is with a upgraded turbo, like a 17, they can be fairly cheap and you can go up into the 18 to 20PSI on them, cleaned intake and head will help too.
also TUNE TUNE TUNE
who wrote it and how old is it?
