I've seen this thread multiple times, with various different answers...hoping someone who has done this on a BRM specifically can chime in.
My master cylinder pushrod broke, so I decided to buy a replacement master and slave at the same time. The slave came in but was the wrong part, so I replaced only the master. In bleeding the system (from the bottom bleed on the slave), I was able to get some clutch pressure...but not enough to fully engage the clutch. It would tick while running, this makes me think I still have air in the system.
Would a motive pressure bleeder really fix this as everyone says? The pressure bleeder and I would be bleeding the same section of line that I've already done, while still being unable to bleed the 2 inches of accordion on the slave beyond the bleed that extend into the transmission (where I think the air is tucked away).
In trying to bleed it, the master broke apart, so I have to restart the job. Still worth buying a correct slave and doing it at the same time?
