Since I bought my car new, I’ve been disappointed with how inaccurate the mpg numbers that are shown in the MFD. When I recently bought a VCDS, I found out that I could adjust the calculations used by the MFD to make the mpg information more accurate.
https://idpartsblog.com/2018/03/26/adjusting-displayed-fuel-economy-on-mk7-tdi/
I hadn’t been tracking the MFD indicated mpg per tank, but I did feel that the numbers seemed to be about 8-10% high. So I made my initial adjustment to 1.05 and started tracking the indicated mpg against my externally calculated mpg for the same tank.
The next three tanks looked like this:
tank 1 - 478 mi., mfd mpg = 36.6, calc mpg = 35.9, error 0.7 mpg or 2.0%
tank 2 - 508 mi., mfd mpg = 43.6, calc mpg = 41.8, error 1.8 mpg or 4.3%
tank 3 - 527 mi., mfd mpg = 42.3, calc mpg = 40.6, error 1.7 mpg or 4.1%
That led to an averaged 3.5% error overall with the adjustment set to 1.05. So I changed the adjustment value to 1.09 using my VCDS, while sitting at the gas station of that last fill up. I am just about ready to fill my first tank with the new setting of 1.09 and will be interested to see how close it is now. Of course, one tank is just one data point and not enough to declare victory.
My goal is to get the mfd to match my calcs +/- 0.2 mpg. That would put my mfd at 99.5% accurate, which would be good enough for me.
So the point of this thread is to ask if anyone has done the adjustments and what adjustment value did you decide was good enough?
BTW, tank 1 mpg looks low because it included 250-300 miles towing a 1400# trailer. Given that, it looks better now, doesn’t it?
