i have recently noticed a screeching sound emitting from drivers side.
today the low coolant level light came on and there was coolant on the ground.
i have removed the front drivers side wheel and the wheel arch liner and discovered the leak around crank shaft pully, down the side of the sump and the soft cover under the sump was drenched.
is it a failed water pump?
could it be the metal coolant pipe above the crank shaft pully which had a drip on it and this is leaking coolant onto the side of the sump?
thanks.
thanks.
