I don’t have VCDS. I meant a static test by providing 4VDC to the QA to verify that it’s functional. 5 VDC should run the QA to 100% travel. I just want to test it to rule it out as a problem. The system isn’t running the QA 0-100-0 on key on.
Thank you.
I have a write up in the MKIII thread: http://forums.tdiclub.com/showthread.php?t=500368
I have 12 VDC at Pin 5 from the ECU, but am also reading a PWM signal of 161 mS pulse width and a Duty Cycle of 98%. No P to P value.
Just verified continuity from IP plug to ECU for pins 5 and 6.
Next step is verifying continuity from ECU plug grounds.
Thought I’d hit the QA with 5 volts DC to at least verify functionality.
