Herm TDI
- Joined
- Nov 21, 2001
- TDI
- 2002 Golf GLS Malone Stage 3, P+520 nozzles, 11MM Inj pump, Sachs VR6 clutch, Stelth Race Pipe, Immo Deleat, EGR Deleat
Car Info: 2k1 NB TDI
I need a compleate MAF Connector and wires.
If you have or know of a wrecked A-4 or NB...please give me the owner's contact info.
The problem is ....A "Stealership" has literaly hacked this poor TDIs MAF harness to death. I have never seen such sloppy repair work in my entire life.
Currently the condition of the connector is useless. Repair is not an option. This leave a replacement as the only means to make an effective repair.
So to clarifi exactly what I need....
I need the whole MAF electriacle connector and about 3" of the wire harness. The wires lead from the MAF connector and back towards the line feed.
The owner is desperate...if you think that you might have had MAF problems with your TDI...you havn't seen squat till you've seen this mess.
If you can help...TIA
Herm
Herm
