Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old January 23rd, 2012, 17:34   #1
latitude98
Fuel Economy: avg. 37 mpg on 5% biofuel
Default Breeze on shifter hand when turning 2012 Jetta tdi
When I make turns in my 2012 Jetta tdi manual, i occasionally feel a cold breeze on my shifter hand. i know it's not coming out of the air vents because i have hot air blowing; it being the winter time and all. Does anyone else have this problem or any ideas on what it could be? It feels like it comes through the area where the shifter comes out of. I've checked the plastic and pleather wrap and I didn't see any holes.
latitude98 is offline   Reply With Quote
Old January 23rd, 2012, 18:37   #2
tdipoet
tdipoet's Avatar
Fuel Economy: 1 Hojillion MPG
thats the sweaty palms prevention vent. you wouldn't want your hand to slip during critical shifts, would you? look, i know these cars are decontented, but they're not going to just remove an essential feature that makes driving safe and pleasant like the SPPV.
tdipoet is offline   Reply With Quote
Old January 23rd, 2012, 19:53   #3
latitude98
you know I had to google that just to be sure lol
Old January 24th, 2012, 04:24   #4
FVWVWF
FVWVWF's Avatar
Haha...I googled it.
Yeah I get the cool breeze too....checked everywhere and cant find squat. And it doesnt always happen either.
FVWVWF is offline   Reply With Quote
Old January 24th, 2012, 04:49   #5
latitude98
I'm taking it to the dealer today for the 90 day courtesy inspection and I'll ask about it.
Old January 24th, 2012, 20:05   #6
latitude98
Well of course the dealer couldn't replicate the problem. I guess I'll just deal with the nuisance. I hope it doesn't lead to a major problem later on.
Old January 26th, 2012, 08:57   #7
detroitmike
detroitmike's Avatar
I wish I had Your problem.....I'm driving around with a piece of my air intake pipe boucing around in my trunk while I wait for the D-bags at VW to fix my IC problem.
Power Service Diesel Fuel Supplement every tank
detroitmike is offline   Reply With Quote
Old January 26th, 2012, 09:41   #8
MayorDJQ
Is the shift boot seated correctly? IIRC, there's a foam rubber piece of insulation under it. Maybe that's missing, installed incorrectly, or a de-contented item.
MayorDJQ is offline   Reply With Quote
Old February 13th, 2012, 13:23   #9
FVWVWF
FVWVWF's Avatar
Originally Posted by MayorDJQ View Post
....there's a foam rubber piece of insulation under it. Maybe that's missing, installed incorrectly, or a de-contented item.
Took mine to the dealer...that was exactly the issue. Rubber piece was twisted in there, they replaced it.
Old February 13th, 2012, 17:35   #10
pipes p
i know in mine if you turn one way you get more heat, turn another and it gets cooler air. i think its how much more/less coolant goes into or out of your heater core when turning.
pipes p is offline   Reply With Quote
Old February 13th, 2012, 17:45   #11
MayorDJQ
Not likely. Cornering should have no affect on coolant flow through the heater core.
Old February 14th, 2012, 09:50   #12
mliddell
You think this can happen in a DSG vehicle? Or am I just suffering from a placebo effect? I swear when I make right hand turns in my DSG my hand gets a breeze.....
mliddell is offline   Reply With Quote
Old February 14th, 2012, 14:00   #13
Softrockrenegade
Softrockrenegade's Avatar
I get cool breezes too when turning !!!!!
Softrockrenegade is offline   Reply With Quote
Old February 17th, 2012, 11:25   #14
jnmarshall
Could this possibly be the effects of Newton's first law? The air leaving the vent when a turn occurs will move in the original direction of the vent. So I could see for a split second how you could feel a breeze or a change of hot and cold air. It's a common occurnace when flying a small plane, especially when it's VERY cold out.
jnmarshall is offline   Reply With Quote
Old April 23rd, 2013, 18:20   #15
flyerchic2000
Hi. I posted about this problem with my 2011 Jetta. I feel a burst of cold air when turning. See my post here http://forums.tdiclub.com/showthread.php?t=345845
Did fixing the shifting gear gasket help? Did anyone else find a solution to this?
Thanks!
flyerchic2000 is offline   Reply With Quote
Turning motor over by hand RabbitGTI VW MKIII-A3/B4 TDIs 10 January 26th, 2020 16:56
Breeze on shifter hand when turning 2012 Jetta tdi latitude98 TDI 101 8 October 16th, 2013 13:00
Tdi Fest 2012 Grvd.. Wanna lend a hand? Interested in making it a reality? glitdi West Coast Canada/USA 13 October 8th, 2011 09:09
Photos, 2012 Passat TDI, UK right hand drive Melensdad VW Passat Family (NMS and B7) TDIs (2012+) 7 October 7th, 2011 10:36
Turning engine over by hand dieselt VW MKIV-A4 TDIs (VE and PD) 2 October 26th, 2004 14:49
Page generated in 0.15171 seconds with 11 queries
[Output: 121.13 Kb. compressed to 100.69 Kb. by saving 20.44 Kb. (16.88%)]
