Old January 22nd, 2012, 17:05   #1
latitude98
Fuel Economy: avg. 37 mpg on 5% biofuel
Default Breeze on shifter hand when turning 2012 Jetta tdi
When I make turns in my 2012 Jetta tdi manual, i occasionally feel a cold breeze on my shifter hand. i know it's not coming out of the air vents because i have hot air blowing; it being the winter time and all. Does anyone else have this problem? It feels like it comes through the area where the shifter comes out of.
latitude98 is offline   Reply With Quote
Old January 23rd, 2012, 14:32   #2
latitude98
Bump. No ideas from anybody.... I had a 2010 Subaru wrx and never had this problem. A cold draft on my shifter hand when turning. Not coming from the vents but feels like it's coming from the area that the actual shift stick comes out of. I can't visible see any holes in the plastic or pleather wrap. Maybe a seal problem or thats just the way vw's are. I guess I'll be bringing it up to the dealer once I get my bluetooth module fixed.
Old January 23rd, 2012, 16:09   #3
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
My '96 and '97 Passats had a somewhat related issue: The air flow out of the dash vents and floor vents would cool on right turns and would warm on left.
Weird, eh?
Off ramps were cooler than driving straight and it wasn't related to road speed, because rotaries would produce a warmer air flow than the same speed on the straight leading to and from it.
Keep turning left by going 'round and 'round and it would remain as if the temperature knob were turned to a warmer temp. Empty parking lot right turning circles were as if the temp were turned cooler.
Svante Arrhenius 1896
Old January 23rd, 2012, 16:14   #4
dieselpony
dieselpony's Avatar
Fuel Economy: Too soon to tell MPG
I notice cool air on my left hand from the door speaker, but not from around the shifter.
2015 Jetta SEL 6MT Moonrock Silver; 2 BRMs that will soon be listed for sale. I have hex-can vcds and am willing to help.
dieselpony is offline   Reply With Quote
Old January 23rd, 2012, 16:59   #5
latitude98
Thanks for your thoughts. I contacted the dealer and they are going to take a look. Will post what they find if anything.
Old January 24th, 2012, 20:07   #6
latitude98
Well of course the dealer couldn't replicate the problem. I guess I'll just deal with the nuisance. I hope it doesn't lead to a major problem later on.
Old January 25th, 2012, 06:49   #7
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: 130 MPGe
Open up the center console and check the insulation around the shifter. It's possible that it's not installed correctly or there's a gap in it somewhere.
This won't cause long term damage.
Old January 25th, 2012, 12:42   #8
Powder Hound
Powder Hound's Avatar
The solution to your problem is to keep both hands on the wheel except when you are actually changing gears. The shifter is a terrible place to rest your hand - it causes shifter fork and gear wear and can lead to an early death of the transaxle.
Yes, yes, I know you are the only person in the entire universe that puts absolutely no stress or pressure of any kind on the shifter knob when you rest your hand there, but really, just play along and set a good example for others.
Old October 16th, 2013, 13:00   #9
flyerchic2000
Default Yes. I feel this too!!
I have a 2011 tdi. I have felt this same breeze you speak of. Please see my thread posted in March 2012 http://forums.tdiclub.com/showthread.php?t=345845
Did you ever figure out what it was?
flyerchic2000 is offline   Reply With Quote
Turning motor over by hand RabbitGTI VW MKIII-A3/B4 TDIs 10 January 26th, 2020 16:56
Tdi Fest 2012 Grvd.. Wanna lend a hand? Interested in making it a reality? glitdi West Coast Canada/USA 13 October 8th, 2011 09:09
Photos, 2012 Passat TDI, UK right hand drive Melensdad VW Passat Family (NMS and B7) TDIs (2012+) 7 October 7th, 2011 10:36
Turning the crank by hand? CGDoig TDI 101 2 March 28th, 2011 18:16
Turning engine over by hand dieselt VW MKIV-A4 TDIs (VE and PD) 2 October 26th, 2004 14:49
Page generated in 0.16212 seconds with 11 queries
[Output: 90.14 Kb. compressed to 77.14 Kb. by saving 13.00 Kb. (14.42%)]
