Old August 20th, 2008, 09:52   #1
10-cc
Default Elf DID 5W40 mix 50% 50% with INEO MC3 5W30
I have a couple of Liters Elf DID 5W40 left (505.01) they are no longer stock, they been replaced by Total Quartz INEO MC3 5W30 (505.01).
The question is:
Can I mix both oils for my next oil change? Say 2 Liters of Elf + 2.5 Liters of Total?
Thx
Jetta TDI 2005.5 Platinum Grey, stick
10-cc is offline   Reply With Quote
Old August 22nd, 2008, 10:51   #2
10-cc
If both are 505.1 complient it should be ok to mix.
Thanks in advance.
Old August 22nd, 2008, 12:05   #3
Waldek Walrus
Fuel Economy: 54/47/42
The question is:
Thx
That mix is what is in my crankcase right now and is about to be changed this weekend with 10,000 miles on it. According to Indigo Blue Wagon these can be mixed as needed for 505.01 appllications. There should be a couple of threads on that buried somewhere. From what I understand this is basically the same stuff. Enjoy!
Doug
'06 TDI NB (Julie Bug)
'11 GMC Acadia
'01 Buick Lesabre - boulevard ride
Waldek Walrus is offline   Reply With Quote
Old August 22nd, 2008, 12:20   #4
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
Thanks in advance.
None of them are 505.1 compliant however they are both 505.01 compliant.
Total formerly was Elf. Probably the exact same stuff right down to the oil basestocks.
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old August 22nd, 2008, 14:01   #5
HopefulFred
HopefulFred's Avatar
Fuel Economy: ~39 USMPG
Even if it wasn't the exact same stuff, under what circumstances would it not be OK to mix oils that meet the same VW spec?
Novice VCDS user.
Proud owner and successful two-time user of AST timing belt tool kit.
HopefulFred is offline   Reply With Quote
Old August 25th, 2008, 10:05   #6
10-cc
Thanks I will be mixing them 505.01, sorry for the misspell
Old August 25th, 2008, 14:26   #7
Zero10
Zero10's Avatar
There are many people who would complain about conflicting additive packages when mixing oils from different brands, but if you are staying with the same company, using the older oil and the one that replaced it, I wouldn't worry at all. Go for it.
87 Porsche 951
05 Golf GLS TDI
Zero10 is offline   Reply With Quote
Page generated in 0.13699 seconds with 10 queries
[Output: 77.09 Kb. compressed to 65.98 Kb. by saving 11.12 Kb. (14.42%)]
