gottdi
Here is my list. I know most will be purchased new but I wanted to post anyway. Bold text items I want good used if you have em.
Parts are for my A4 TDI 01 Beetle Manual transmission.
I do need a skid plate but that may have to wait unless you got a good used one on the cheap.
Drivers side Transmission mount with bolts
Passenger side engine mount bolts
Dogbone mount bolts
Oil filter flange gasket
water tube o-ring
valve cover gasket
intake gasket kit
exhaust gasket
flex tube gaskets
green coolant temp switch w/o-ring
thermostat
g12 coolant (not sure how much I need)
fuel return line (bio-compatable)
vacuum line
Good low mileage Pressure plate (one that has more pressure than stock) Staying with my stock dual mass flywheel setup.
Throw bearing
clutch disk.
PM me with what you have. I also have this list forwarded to others to see what good deals I can get in bulk.
Engine swap project going well.
Dogbone mount bolts
water tube o-ring
valve cover gasket
intake gasket kit
exhaust gasket
flex tube gaskets
thermostat
vacuum line
Throw bearing
clutch disk.
