Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2012
TDIFest 2012 Discussion about TDIFest 2012 on the Labour Day weekend (August 31st to September 2nd, 2012) in Ypsilanti (Ypsi), Michigan.
Old August 27th, 2012, 07:26   #1
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Default good places to fill up on Bio Diesel on the way to Fest?
Heading out to Fest during the wee hours of Friday morning, Going to be driving West from Cape Cod. Anyone know of a good refueling stop within the range of AHU fuel tank??
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
GTiTDi is offline   Reply With Quote
Old August 27th, 2012, 07:42   #2
loganbmx4gt
loganbmx4gt's Avatar
There are some in PA I do believe. I have to check my list. Looking for B99/100?
loganbmx4gt is offline   Reply With Quote
Old August 27th, 2012, 09:09   #3
GTiTDi
GTiTDi's Avatar
Or B20...I usually run B20.
MK2 GTI build
schnellsnailFB
Old August 27th, 2012, 09:33   #4
loganbmx4gt
Are you cutting through Canada or staying in the states?
If staying in the states, try Full Circle Fuels 141 South Main St Oberlin, OH 44074; 440-574-5436. Looks to be < 800 mi from your parts. They have B100.
Old August 27th, 2012, 11:43   #5
GTiTDi
GTiTDi's Avatar
Was planning on staying in the states but that can always change.
Thanks for the info Logan! Much appreciated!
MK2 GTI build
schnellsnailFB
Old August 27th, 2012, 12:33   #6
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: 130 MPGe
Beware of the Meijer stations around the Fest location. One of them, in particular, has a history with algae.
Old August 28th, 2012, 17:31   #7
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
If I need fuel when I'm heading up into Michigan, I usually stop at the Pilot at 223 and 23 in Ottawa Lake, MI. Exit 5, signs for Blissfield and Adrian. They've got B10, at least.
Originally Posted by Upton Sinclair
It is difficult to get a man to understand something, when his salary depends upon his not understanding it!
bhtooefr is offline   Reply With Quote
Old August 29th, 2012, 05:38   #8
deegingerkid
Beware the Ginger! Vendor
Fuel Economy: 38-44 depending on lead-footed-ness and highway/city proportion
B5...(I know, I know...practically D2...) @ Mid-Wood co-op on gypsy lane rd in Bowling green,
Ohio. It's my regular fuel-up and it's on the way for anyone coming up I-75. PM me for specific directions or google it! They are 24 hours and credit only. There is a kiosk...make sure to select pump no 5. It's the only car nozzle.
Ohio to California transplant and loving it!
2k Beetle, Batik Blue, 5sp., Stage 3 TDtune, front knuckle upgrade (from 1.8T), Seat Cupra R rear axle bushings (I rather like tasteful and discreet upgrades)
I'm a ginger. You've been warned.
deegingerkid is offline   Reply With Quote
Old August 29th, 2012, 06:09   #9
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
My regular fill-up is at the BP/Englefield Oil commercial filling station on Union St. in Newark, and they've got a few stations in the Columbus area, too. They've got B5, B10, and B20 at the pump.
Old August 29th, 2012, 06:50   #10
loganbmx4gt
If you want another B99 choice, there is JatroDiesel; 845 North Main Street Miamisburg, OH‎ 45342. Its in the Dayton region. They are open 8-5 M-F and anybody heading north through Ohio will have to pass the exit. I know I will be stoping in, and Jon aka Lug_Nut stopped in today.
Old August 29th, 2012, 07:25   #11
GTiTDi
GTiTDi's Avatar
I'm thinking of carrying a 5 gal can of B99 so I can splash blendw D2 a couple times if I can't find B20.
MK2 GTI build
schnellsnailFB
Old August 29th, 2012, 17:46   #12
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
JatroDiesel; 845 North Main Street Miamisburg, OH‎ 45342. ...Jon aka Lug_Nut stopped in today.
And I'll be back in the morning. I had an errand to run and need to top off before leaving the Dayton area.
Their posted hours are open at 8 am, but expect to hang around for 30+ minutes until someone actually shows up.
They have fuel, presently B100, $3.59 per gallon available from the tanker at the offices there on Main. It's not needed to cross the river to the production site. The pump display at the office is in error by a measured percentage. Jatro have a multiplier factor to correct the pump display to true dispensed volume.
Which Meijer, the one at 3825 Carpenter? That looked to be the closest with B20.
If the quantity of carbonic acid increases in geometric progression,
the augmentation of the temperature will increase nearly in arithmetic progression.
Svante Arrhenius 1896
Cogito ergo soy (I think, therefore: Biodiesel)
Lug_Nut is offline   Reply With Quote
Old August 29th, 2012, 23:33   #13
Good Ol' Boy
VeeDubTDI's Avatar
I think that's the one.
Old August 30th, 2012, 17:25   #14
GTiTDi
GTiTDi's Avatar
Picked up 5 gal of b99 at Loud Fuel in Falmouth this afternoon, for on the road splash blending!
MK2 GTI build
schnellsnailFB
Old September 9th, 2012, 15:22   #15
gary9696
Fuel Economy: 38.9/45 - 54
Which Meijer station near where the fest was in Michigan has the algae problem? I live nearby in Canton Michigan I usually use the Kroger diesel, and Power Service (Diesel Kleen +Cetane boost) additive.
gary9696 is offline   Reply With Quote
Good places to get a timing belt done? pnyknight Ontario 30 January 13th, 2012 09:41
Any good bushing places k45 Upgrades (non TDI Engine related) 2 August 14th, 2007 08:21
Bio Diesel Good for Particulate Filters! Spokane Walt Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 July 25th, 2006 10:50
Is this good bio-diesel fo fo weed Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 9 January 31st, 2002 23:04
2 good Diesel specialty repair places IL and IA GeWilli VW MKIV-A4 TDIs (VE and PD) 0 December 7th, 2000 07:53
Page generated in 0.18469 seconds with 14 queries
[Output: 136.53 Kb. compressed to 114.18 Kb. by saving 22.35 Kb. (16.37%)]
